Old 07-05-2018, 10:07 PM   #1 (permalink)
Ale Madeo
ale0502's Avatar
pwm frecuency
Hi,
I understand that the pwm frecuency must be 10KHz, but on my board is about 3KHz.
My crystal is 8MHz.
What could be wrong?
Thanks
Los que dicen que es imposible, no deberían molestar a los que lo están intentando...
Old 07-06-2018, 02:38 PM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
"Must" be 10KHz?
Not sure what you're using it for, but they can operate at whatever frequency suits best. Higher frequency is usually used for "silent" operation, though. The higher the frequency, though, the more switching losses you get...
Without knowing how your board works, one can only guess what's wrong. Can whatever chip is doing the counting keep up with the frequency of the crystal? Is it getting a strong enough signal from it? Can't tell ya.
I suppose if you had a signal generator, you could simulate the crystal's output and use it to diagnose...
