EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Question about full front air block (https://ecomodder.com/forum/showthread.php/question-about-full-front-air-block-6120.html)
Sean T. 11-21-2008 10:14 PM
1 Attachment(s)
I know that the idea is to get a teardrop shape, but I am having a bit of a problem with my air dam. I have an indent on my front bumper for the license plate and it causes the air dam to curve in a little bit, almost like a dent.
What would be the consequences of having it be like that? I mean would it hurt more than help.... ?
The ideal air dam is on the left, and (almost) mine is on the right... (overhead view)
SVOboy 11-21-2008 10:17 PM
It's prolly not that bad since air will just form a high pressure pocket there, right smarties?
Sean T. 11-21-2008 10:18 PM
That's what I'm hoping, but with the MPG contest, I am nervous to test it....
aerohead 11-22-2008 01:27 PM
dent
I'm with SVOboy on this one,and the flat area may augment the stagnation pressure in a positive way,which would be even more important with the blocking as you've pictured.
Sean T. 11-22-2008 02:50 PM
Well, it's official. Rex was participating in "No-shave November" and now he has a full moustache...
http://img.photobucket.com/albums/v2...r/IMG_1003.jpg
http://img.photobucket.com/albums/v2...r/IMG_1004.jpg
http://img.photobucket.com/albums/v2...r/IMG_1002.jpg
Oval_Overload 11-22-2008 09:54 PM
Rex wins Novembeard!
If you decide to eliminate the license plate dent, just put some washers between the bumper and air dam.
