EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   a question for the aero guys! (https://ecomodder.com/forum/showthread.php/question-aero-guys-31077.html)
NickelB NL 01-29-2015 03:36 AM
I.ve been thinking about it for days now. Afther reading a bit into mirror designs and the high preasure at the windshield and high turbulance around the a pillar.
What about spoilers/flaps to fill in the angle between fender and a pillar. A flat plate welded in or if ducktape wil hold for testing or other manners. But i my mind if you box in the high preasure at the base of the windshield and "cut" the air with the same plate for better attached flow on the sides and around the mirrors. Sorry for my schetchy explanation. I.ll try to make a hand drawn schetch and upload it
NickelB NL 01-29-2015 03:44 AM
1 Attachment(s)
Here i a quick sketch (sorry for the childish car haha) and the spoiler/flap is filled in. Also i think a car with a bigger transsition from bonnet to windshield would proffit more frome this.
Hope you guys know something about it. Or ill try it when weather gets better and make a coroplast mockup for it and do a a-b-a-b with tufting.
dirtydave 01-29-2015 05:15 AM
A windshield wiper cover like?
Or like a hood cowl?
NickelB NL 01-29-2015 06:11 AM
1 Attachment(s)
Not like that. More like wing end plates on big spoilers. The would trap the high preasure and let it move over the windshield as not to let it spill it around the A pillar. Thus redusing drag around the a pillar.
Ok it would be some trail and error to find the correct shape and size for each car.
I.ve made a simple top and front views to. Also the plates are highlighted.
Eddie25 01-29-2015 07:06 AM
better make it out of clear Perspex you will have a big blindspot there
MetroMPG 01-29-2015 07:15 AM
Seems like a good idea at first blush, but it would make things worse. The airflow at the base of the A pillar isn't traveling straight back in a way that could be meaningfully 'corraled' like that- it's going across at a good angle. So that plate would cause separation & recirculation behind it, and that would make a mess of the flow along the side of the car.
NickelB NL 01-29-2015 07:26 AM
I think i know what you mean. But would it also be so if it is gap sealed. With no leaks from the high preasure part?
Frank Lee 01-29-2015 07:32 AM
I think if it is sized and curved properly it could work.
MetroMPG 01-29-2015 07:37 AM
Better than a flat plate, sure.
Good luck fine tuning it outside of CFD or a wind tunnel!
NickelB NL 01-29-2015 07:49 AM
It would take alot of trail and error. To make it big enough to not let it spill the high preasure and to make it flow nice
Frank Lee 01-29-2015 07:49 AM
I don't know how hard it would be to make it work. Aerohead turned us on to a way of correcting downstream flow on square-edged forms like trailers and camper shells and even truck cabs and it was a curved "leading edge fin".
MetroMPG 01-29-2015 08:38 AM
It's going to spill regardless. The idea of the curved portion Frank mentioned is to control the spill in a way that keeps the flow "clean" along the sides.
I'm going to play devil's advocate here, but I think automakers have already put a lot of time into optimising A-pillar design for current windshield angles. Short of fully encapsulating & shaping the whole front end from the leading edge of the hood to the roof (which requires adding a second windshield), I don't think there's much to be gained.
Frank Lee 01-29-2015 09:02 AM
And if there's a rear view mirror there it might negate any benefit.
New Civic A-pillar/windshield relationship is kind of similar.
2000mc 01-29-2015 11:04 AM
I'm afraid it would be like working with a box plow. no flow over the edges, unless you keep going until it's full. Then you're still spilling over, but you'd be pushing more at the same time.
spacemanspif 01-29-2015 01:11 PM
I have to agree with Frank, the civic has a recessed windshield with a protruding a-pillar and I believe the new Focus and Fiesta have a similar set design. There was a post on here about Mercedes experimenting with a-pillar fences but can't remember it off the top of my head. Also, doesn't the old Beatle benefit from such fences? I'll have to do more digging when I'm not on my phone...
I think the original idea is a neat one just to try and block so much air coming into contact with the side mirror. Let the air up the pillar spill over like normal, but redirect some flow away from the problematic mirrors... Some triangles of coroplast should be easy enough to cut up and stick on for testing. Tuft test the windows and sides of the car and only treat 1 side so you can compare if there is extended turbulence on the non-treated side. I'm assuming the faster you regain attached flow, the better off you are.
Joris 01-29-2015 03:14 PM
http://performancedrive.com.au/wp-co...AB-concept.jpg
The Eolab has fences, but the air can flow through them. They must have done that for a reason.
serialk11r 01-29-2015 03:32 PM
I first thought it might be for structural reasons then I realized that is probably not the case. Perhaps the fences help bend the air around the A pillar so there's less vorticity.
freebeard 01-29-2015 04:36 PM
It might make things worse. If the mirror is visible from the front of the car, it's part of the frontal area. Blocking the flow off the windshield might change the angle of the oncoming air, but that would drive the drag toward similar to the stagnation point.
spacemanspif mentioned old Beetles. This is cribbed from racing 911s:
http://www.gerrelt.nl/mirror/beetle_...alifornia1.jpg
http://www.gerrelt.nl/section-aerodynamics/aerodynamics-vitaloni-mirror.html
Mirrors are problematic because the optical requirement demands a flat plate and they are located in a complex flow. Peep mirrors and fendertop mounted mirrors address this. Peep mirrors are closer to the drivers eye and can be smaller.
The Eolab is interesting. I wonder how much of that is not just styling. Ferrari took the opposite approach...once.
http://i.imgur.com/Z8q8D.jpg
renault_megane_dci 01-29-2015 04:44 PM
Nothing fancy : the windshield angle is steep so there is less heavy glass but it wouldn't look aero from the side so they made fake A pillars which didn't detract flow (measured).
Aero performance is very much in the back of a car anyway.
aerohead 01-29-2015 05:29 PM
high pressure
The stagnation bubble atop the cowl area is not responsible for flow over the windshield or A-pillars.It doesn't go anywhere,but rather travels along with the car,stuck right there.When the ventilation damper is open,this pressure pushes air into the HVAC system.
In a rain,you may see the air (pushing water ) go sideways at the bottom of the windshield,at a 45-degree angle at the top sides,and vertical in the center.
As MetroMPG mentioned,if you place a capping plate/fence near the A-pillar base,the transverse flow will trip over it,creating flow separation and turbulence right there.
Modern cars which have the valley between the A-pillars were designed for that.The fenders,hood,windshield,and A-pillars were all done from scratch to accommodate that feature.To dial that in on a car not designed for it might not be doable.If it could,you'd need,according to many new graduate engineers,and also mentioned ,top of the line CFD or a full-scale wind tunnel.
Personally,I'd recommend you spend your time elsewhere.
Cd 01-29-2015 05:59 PM
I had a similar question some time ago :http://ecomodder.com/forum/showthrea...ces-21242.html
By the way, look at the " fences " used around the Shelby Daytonas' windshield.
( The small piece just above the mirrors - you can see them better at 0:46 in the video )
https://www.youtube.com/watch?v=buWIbGEd-lc
Sounds like a popcorn maker too me when at idle.
NickelB NL 01-30-2015 05:03 AM
Already thanks for all your input. I may of may not try it. It was just an idea floating around. And in my mind the ford ka isnt made for aero. So there would be much to win
Eddie25 01-30-2015 05:46 AM
3 Attachment(s)
saw a 2009 merc b class yday and couldn't help but noticing the windscreen looking like its recessed in from the pillars not sitting flush like most cars.
Attachment 16857
Attachment 16858
Attachment 16859
NickelB NL 01-30-2015 06:10 AM
Now i see these cars. There are alot of cars that have such fences. Peugeot's and citroen's have thos alot. Also some fords and more. but will it be for aero or not. Those would be doable to make and test. Take a 40mm pvc sewage pipe and cut them lengtways and put them on. Make it flush with tape and test it
Frank Lee 01-30-2015 08:39 AM
The nice thing about testing these is you can tuft the area and watch it as you drive (unlike things out back).
Frank Lee 01-30-2015 01:11 PM
2012 Maxima has what you are looking for.
freebeard 01-30-2015 04:51 PM
That might work in the rain, but I question whether it would work in snow.
aerohead 01-30-2015 05:08 PM
A-pillars
Whatever the reason for the 'new' design,it looks like they're a hazard to pedestrians.
Here's a link to a safety concept
http://cms.ukintpress.com/UserFiles/.../42312_1_5.jpg
NeilBlanchard 01-31-2015 09:33 AM
The 2015 Leaf (and maybe other years?) also have these deep recesses in the 'A' pillars.
renault_megane_dci 02-01-2015 03:48 AM
Maybe it is just a way to get bigger A-Pillars without creating too much of a blind angle ?
We have those kinds of issues on cars ...
aerohead 02-02-2015 05:55 PM
A-pillars
Here in the 'States,' roof strength regulations are pushing stronger 'pillars'.
Pedestrian safety regulations are raising cowls.
The submerged cowls may also have to do with safety,and to provide enough pressure for fan-off ventilation.The depression,locked in by the A-pillars may have to do with fresh air as much as drag.
So far,there are no low drag concepts with this submerged cowl.
