Quick question
I am thinking of doing a grille block on a couple cars, but have it behind the grille.
The reasons are: 1) aesthetics 2) protection 3) making it motorized and driven by the radiator temperature to open when more cooling is necessary My question is if there is an appreciable (noticeable) difference in drag for the block to be flush with a grille that is about 1/2" thick, effectively making pockets vs being flush (and smooth on the outer surface)? Since it is not an aircraft or race car, but being driven exclusively below 80mph, does it REALLY matter?? |
flush
There's probably plenty of radius around the grille opening to keep the flow attached,since the whole area is in a favorable pressure gradient,courtesy of all the attacking air in front of the car.
The grille opening itself should have some radius itself,or you can have what is called a vena contracta entry loss,which can invisibly choke down the flow. Here's an extreme example http://i1271.photobucket.com/albums/...Untitled32.jpg The yellow region is nothing but turbulence and a real energy loser.Pure drag.:( |
1) aesthetics 2) protection 3) motorized When you say a couple of cars ...which cars? |
Putting a grill block behind the grill is a lot more work. Not only do you have to get behind the grill, but it's usually not a flat surface that's easy to cover either. And air pressure on a grill block behind a grill will try to push the block away from the grill and let air in. When mounted in front, the air pressure pushes the block tighter to the grill. I wouldn't expect an aerodynamic difference between the two methods if it's well done.
2004 Mercury Mountaineer 2006 Dodge Grand Caravan |
A neighbor works at a race shop and got me some race fans for free, and I know the mechanical fan is a real drag given that simply backing up the driveway blows most of the leaves off the driveway in a 3 foot swath. ;) |
The shuttering mechanism will have to fight the air pressure one way or the other, either opening or closing. And you will need space behind the grille to match the depth of the shutters.
I propose two sheets of perforated metal. Our local recycler has a lot of stainless steel with inch-and-a-half perforations. When the holes are aligned you'd have a ~50% grille block, but slide the inner one sideways and it goes to 0%. |
Maybe you should consider making a custom grille similar to the one used in the previous-generation Volkswagen Polo BlueMotion.
Here is the quick (and dirty) grille block that I did last week
1 Attachment(s)
I did notice a quicker warmup time, and the SG didn't show much difference in the operating temps...hovered right around 180-184 (about 5 degrees warmer than normal).
The mpg change over my typical route was a bit more interesting... My trip to work is about 45 miles each way, and typically by the end of the run with a mixture of city, stop and go highway and cruise control at 75mph, I get an ending average mpg of 18.8 to 19.5 without the block. With a longer trip (125 miles each way) consisting of a little bit of stop and go, but mostly cc at either 62mph or 70mph depending on the segment, I typically see about 20.5 at the end of the trip. With the block, it got to the 19.5 much quicker and topped out at about 19.9. On the longer trip I topped out at 19.8. So...it is mixed results. Makes me wonder if I either did a flush mounted (smooth to the outside edge) grille block, or a complete block...or both if that would improve?? I am now thinking about doing a tonnau cover for the bed and see what that does. Dropping the tailgate saw essentially no change in mpg (less than .2 mpg for the typical trip). The grille block was just some cardboard (with paint) zip tied to the outside of the grille (but recessed inside the grille shell) and a lower block that was about 80% (duct tape over styrofoam). |
Think about a partial belly pan. If you don't do something about the air exiting the plenum of the engine compartment, is will just speed up the air passing through the remaining opening.
But, it also highlights the next experiment that I will try using the baseline (w/o grille block) and get the mechanical air swatter removed and see what difference that makes. My guess is that it will be a bigger improvement on FE given the large amount of air it is always moving...two drives up the driveway clears most of the leaves! |
mixed results
The only way to really know the impact of the mod is to do back-to-back runs with a fully warmed up vehicle on exactly the same route,with and without the mod,in rapid succession on the same day.
Otherwise,there's just too many variables which can impact your mpg. It's why these things are developed only in a wind tunnel,where everything can be accounted for and measured to high precision. |
I know...ABABA type testing. :) I am using about a years worth of SG driving on the exact route daily with appx the exact same driving and within 1mpg consistent results.
I did remove the mechanical fan this weekend and will do a couple days driving to test the results and get a new baseline. I will be installing an e-fan shortly (have all the parts) and then will retest with a more complete grille block that can be removed for some proper testing. Already with the fan removed, the engine does rev more easily/quickly. I suspect that the fan clutch was bad. |
In order to do the ABABA testing do you need something like a scan gauge? Would doing an entire tank of gas for each be good enough? I don't have any means to track MPG without dividing my miles driven by # of gallons filled at the pump.
good enough
*A partial grille-block would only address the entry of the cooling system. *6% of the drag, downstream of the radiator would not be addressed. *You might be looking at a 3% drag reduction. *If so, you could only be looking at a 1-1/2 % mpg improvement. *It would be virtually impossible to detect this unless you had a fully-instrumented and documented test session on a closed course, back-to-back, within minutes of the original run. *Some investigators at the Motor Industry Research Association wind tunnel in England claimed that in any given year, that they might see 7-days when weather conditions would be stable enough to do accurate outdoor testing. *In the U.S.A., crosswind is considered the norm in all driving.(JPL,Pasadena,Calif.) |
IOW, nothing worth doing is easy.
But is there a need to test a grill block? Do they ever not work? :)
Variables include the vehicle, the driving style, the road and the weather. So, maybe.
need
Every vehicle would have to be addressed on a case specific basis. Since all modern cars are grille-blocked from the factory,additional blocking may experience severely diminished gains.Hucho calls it 'saturation.' |
