EcoModder.com
-   -   Rad area mod (https://ecomodder.com/forum/showthread.php/rad-area-mod-36915.html)
Dogman 10-08-2018 10:12 PM
Rad area mod
I have noticed on my Kia Rondo that behind the grille area, but in front of the rad, there is that whole area including the tranny cooler that seems to be a big air trap.
I realize the air “flows through it” but there must be a large degree of resistance too at road speed.
Underneath there is a plastic panel that I am going to try removing to possibly redirect that built up pressure out the bottom and under the car.
Anybody foresee any issues in doing this?
I can’t see any cooling issues arising from this.
:confused:
19bonestock88 10-09-2018 01:53 AM
You wanna force the air to go through the radiator... if it goes under the car instead of through the radiator you’ll overheat...
Dogman 10-09-2018 07:37 AM
ok thanks...so much for that short lived idea LOL.
I suppose over heating could be considered as... counter productive.
Dogman 10-09-2018 07:41 AM
then would there be benefits in installing electric fans and totally closing off the front?
I am totally grasping at straws here.
I love everything about the car...except its above average fuel consumption.
I better not mess with anything that involves the rad area...I will just accept it for what it is.
I can buy a lot of gas for the cost of a ruined tranny or engine.
Ecky 10-09-2018 08:25 AM
Without a source of fresh air, it will continually heat up under the hood until it overheats, even if you have fans. Ideally you'll have a clear path from grille to radiator to undercarriage, and close the grille opening until you have just a little more opening than is necessary in the worst case you see in your driving.
