EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Radiator fan - before or after? (https://ecomodder.com/forum/showthread.php/radiator-fan-before-after-6501.html)
Piwoslaw 12-22-2008 01:55 AM
I've noticed that in some cars the radiator fan is in front, right behind the grill, while in others it's behind the radiator, between it and the engine. I can see +'s and -'s of both placements, but am wondering if one really is better than the other?
ATaylorRacing 12-22-2008 08:38 AM
Just a mater of space.
Mediarocker543 12-22-2008 08:43 AM
As previously mentioned, Its more for Space issues than efficiency.
dremd 12-28-2008 09:52 PM
If you get the choice put it up front.
Pressure works better than vac. When it comes to airflow over a radiator. I solved an overheating issue by switching from a rear mount 16" to a 12" front mount on my supra ( rear is no longer neaded)
