EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   rain gutter (https://ecomodder.com/forum/showthread.php/rain-gutter-36926.html)
Taylor95 10-12-2018 02:50 PM
rain gutter
1 Attachment(s)
Do you think it is worth the time to remove this rain gutter thing from the roof of my car? I don't think water will get into my jeep without it and paint isn't an issue.
https://ecomodder.com/forum/attachme...1&d=1539370110
Piotrsko 10-12-2018 02:58 PM
No but your pants will get wet from the drips and snow falling Inside. I HATE my gutterless vehicles for that reason.
freebeard 10-12-2018 06:04 PM
If you are going to chop the top and round the corners of the doors it's mandatory.
If you're just curious use duct tape and do some A-B-A testing. The lengthways trough isn't the problem, just the dog-leg inward.
oldtamiyaphile 10-13-2018 08:47 PM
The rain gutter holds your roof on. Removing it is not a simple task.
freebeard 10-14-2018 01:24 AM
It can be done.
Saw-z-All 6-8" at a time and weld 'er up.
ThermionicScott 10-14-2018 01:59 AM
Worth the time? No.
seifrob 10-14-2018 04:11 PM
I am no expert, but my opinion is removing gutter running from front to back will have no effect as it does not protrude high enough. As freebeard said, cover with duckt tape, fill with putty, white cement, silicone, or cover it in another manner and watch for results.
But, in my eyes, you risk considerable money for negligible gain in Cd
cRiPpLe_rOoStEr 10-15-2018 01:50 PM
It's already not an aerodynamic vehicle at all, so even a slight improvement may be too subtle if you ever notice it.
Taylor95 10-15-2018 02:36 PM
Well those are all good reasons why I shouldn't take it off. If I ever get another parts car I'll take off the rain gutter on it and see how well water stays out and if it holds the roof together.
I'm sure the effects on mpg are minimal but I think I would still do it (after testing on a parts car) because it would look nicer. A 0.05 boost in mpg from that would be a bonus.
freebeard 10-15-2018 05:21 PM
0.01 more likely. :)
https://www.youtube.com/watch?v=yskF50JQBPo
