Ram Implosion Wings
http://i54.tinypic.com/16o0so.jpg
These kill me, it dawned on me what is the most troubling thing about these. If it provides a benefit, than it must be generating a thrust. Since it is in the airstream, no matter how aerodynamic it is, it will be an aerodynamic drag. So not only will the resultant thrust created by this thing have to overcome the drag it creates, it will have to generate additional thrust in order to provide a benefit to the car upon which it's mounted. Does that make sense? It would need to generate a substantial amount of thrust, and I don't believe it possibly could generate any thrust. This is the aerodynamic equivalent of an HHO generator. Website claims are 100-200% fuel mileage improvements. |
I'm quite comfortable with calling BS on that :) The "theory" is complete gibberish "The solution .. to create a vortex out in front of the car", not even worth independent testing IMHO (and some folks added roof racks to hold their creations).
I don't know WHAT the therory is supposed to be, if it is supposed to make thrust, or maybe just seeing it behind you scares you into wanging open the throttle and reducing pumping losses. There *might* be some cases where a spoiler can help CDA as a band-aid for crummy aero body, but do not expect anything like "...have all seen improved mileage from at least 10-mpg; but most have at least doubled their mileage, and a few of us have achieved 3-x our normal mileage on a limited basis. " Rest assured that is 100% bullcrap. edit: more overwhelming evidence of solid bullcrap: http://quantumgravitics.tripod.com/id3.html "We have a wing on a 78 Lincoln Town Car with a 400 CID engine that is being driven 109 miles round trip daily to work here at Firestone. We tweaked it and are getting 56 mpg out of it at present.The 78 Lincoln Town Car averaged 17.8 mpg before the wing was placed on it." |
So the first thing such contraption would need to do, is cancel out it's own aero drag. How ? Then it'd need to improve the mileage. Again, how ? Quote:
Whenever you see this kind of exaggerated claims, rest assured it's a steaming heap of male cattle manure. :D All few pics on Google are coming from the inventor's or affiliated sites. The one genuine tester on peswiki seems to have reduced his mpg. :rolleyes: |
The troubleshooting guide is a source of giggles though, classic fixes include :
Driving at speeds below 68-mph FIX: Drive faster RIW out of adjustment FIX: Properly Adjust wing Bad/failing shock absorbers FIX: Replace bad or failing shock absorbers Its a little like : World constantly in conflict FIX: Implement world peace |
- electrically powered - apparently some ungodly powerfully motor, drawing it's power out of nowhere - Ramjet Turbine - Ramjets require considerable forward speed to operate well, and as a class work most efficiently at speeds around Mach 3. This type of jet can operate up to speeds of Mach 6. there is no such thing as a ramjet turbine, it's one or the other. Yes i know the SR-71 had a combination of the 2, but one was built around the other. |
ChazInMT -
I've said it before, and I'll say it again ... http://ecomodder.com/forum/member-cf...-iwtb-riwd.jpg CarloSW2 |
^^^i have an aircraft on Flight Simulator X that looks a lot like that^^^
I have a medical aid that looks a lot like that.
I hate getting old(er). |
Depends on your plan I suppose.
Anyway the ones of those that supposedly work (aka some folks were testing them long term) on the forum that discusses those things are NOT mounted to the top of the vehicle, they actually mount them off the rearend a bit (the creator says the further off the rearend the better) Also the only people who claim them to do something are driving vehicles with cardboard box shaped aero on the backend. They also need to angle them like a kamback (they call it tune it). So could that strange thing work off the backend of a box vehicle when placed in the circling vortex there? Maybe, why do I think it would? because my suburban got 2mpg better mileage anytime we had the generator and the pad hooked off the backend to the trailer hitch. My guess is anything that disrupts the spinning air has some sort of aero effect, though I doubt it needs to look like that to work. A real kamback probably works better wouldn't you say? |
Well, at least your TV reception will be pretty clear.
But, it's on the internet, it MUST be true!!!
I was thinking of trying to create my own "ram implosion wing" but not for the same effect they were going for but to mount my two soaking wet shoes so it would get that nice air dried smell as I drove home.
I think I have found the original design concepts...
http://www.kollewin.com/EX/09-15-17/...lpaper3800.jpg |
he he I love phantom's reply, I'm sure the dog would leave my shoes alone with the exhaust smell.. :p
