EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   A rather appealing modular home (https://ecomodder.com/forum/showthread.php/rather-appealing-modular-home-34649.html)
Frank Lee 12-12-2016 05:10 PM
Wikkelhouse - A HOUSE FOR YOU
Fingie 12-12-2016 05:17 PM
too cold for our climate. Still nice, though.
Daox 12-12-2016 07:03 PM
I wouldn't be too sure of that. Assuming good air sealing, and a 6" (150mm) thick cardboard wall (essentially cellulose), you have a home that is likely more thermally energy efficient than the majority of homes today.
acparker 12-12-2016 10:59 PM
Can't make up their mind as to whether the house is supposed to last at least 100 years or 50 years. I guess it depends on how magic the glue is. Kind of reminds me of the roofer's lifetime guarantee -- the life of his business, which he changes every 5 years.
Interesting concept. The marketing dampens any enthusiasm I may have for it.
cRiPpLe_rOoStEr 12-13-2016 08:24 PM
It's an interesting design, if we look at it as a reinforced-plastic house. Anyway, it does look nice.
freebeard 12-17-2016 04:55 AM
Nice enough. The rounded edges will inhibit vortex formation. OTOH:
  • Potential for roof leaks every 1.4m.
  • 3 segments for 25.000 euro? No bath or kitchen?
  • Ceiling and floor have the same finish material, softwood veneer. Is you house that way?
  • Why no hemp fibers? Why?
This book will show how limited its possibilities are.
https://books.google.com/books/conte...ec2H8_xuKHO-3k
https://books.google.com/books/about...d=pDJSAAAAMAAJ
From 1974, 133 pages of hippy sh-tuff, an exhaustive inventory of non-cubiform geometry, and a unique means of 'sphere-point raising'. I treasure my copy, along with Zomeworks and the Dome Cookbook.
samwichse 12-17-2016 04:25 PM
The cardboard could be made of hemp fiber...
Day 22 of 31 Hemp Products: Cardboard
cRiPpLe_rOoStEr 12-18-2016 04:16 AM
There might be some way to seal those gaps and avoid roof leaks.
The cost really doesn't seem to justify.
That might be an Euro deal. I've already seen a few colonial houses made entirely of wood, from their ceilings to the floor.
I guess sourcing the hemp fibers would be the issue, but there are other crops that could be used for the same purpose.
freebeard 12-19-2016 12:06 AM
Seals = potential leaks. Not saying it can't be done, with tongue and groove or O-ring seals. But lapped or guttered seams, or post-tensioning would be my preference. A detail cross-section would tell the story.
Colonials prolly didn't use softwood veneer for flooring. More likely hardwood planks. I know raw veneer is a euro-scandinavian thing. Back in the 50s in the PNW they made veneer from old growth timber with really nice graining and then sand-blasted it to give a nice 3D texture.
Hemp is an annual crop so production can ramp up quickly once the artificial constraints are removed.
cRiPpLe_rOoStEr 12-19-2016 09:54 PM
I was thinking about those silicone-based glues used by plumbers and some mechanics due to their resistence to moisture and extreme temperatures.
At least in the 3 southernmost Brazilian states some native woods such as Araucaria were used, but that's not an easy option anymore.
I'm not so unfavorable to industrial uses of hemp-derived products, or even medicinal applications. A few friends of mine actually engage in "recreational" use of marijuana, but I have some objections to it.
freebeard 12-20-2016 04:00 PM
Well, if they're still you friends, that's good.
http://i0.wp.com/www.elsafari.cl/wp-...size=700%2C467
http://www.elsafari.cl/2016/04/27/wikkelhouse-una-casa-carton/
I wouldn't glue everything into a solid mass. This sort of structure benefits from being (at least potentially) relocatable. Having given it a few seconds more thought — Instead of clamping each gap, cut-to-length cables between end cap plates. It might require embedding conduits.
The picture I found shows two options for more durable flooring materials. Here's another with an exterior finish and windows I would prefer.
http://www.architectureadmirers.com/...dmirers-00.jpg
http://www.architectureadmirers.com/wikkelhouse-by-your-wishes-and-needs/
The design has the same flaw as an A-frame cabin The two short walls have all the doors and windows. That row of portholes is as good as it gets. I think you could cut a half-circle out of adjacent modules and get a larger opening, maybe even a doorway.
