Ratio Zero Transmission
You already know the first eight and a half minutes:
This Is The World's First Geared CVT and It Will Blow Your Mind - Ratio Zero Transmission -- ?t=513 Prototype to bicycle level, ICE TBD. Clutchless and smoothened. |
Very clever.
But perhaps not the cleverest I have seen: "...The performance of the car was exactly as George had predicted, 100 miles per gallon of petrol at 38 miles per hour...." In the aerodynamic equivalent of a wheeled outhouse with the door open, on carburetors! George Constantinesco: Inertial Transmission (US Patent 1591471 etc) https://upload.wikimedia.org/wikiped...inesco_Car.jpg https://en.wikipedia.org/wiki/Consta...co_(automobile) I do hope this gearbox goes somewhere, but am acutely aware of 'aversion to change' atm. :) |
en.wikipedia.org/wiki/General_Motors_streetcar_conspiracy#Early_years |
https://www.youtube.com/shorts/Cn1Iakq7v9c I cant help wondering who it was that wanted everyone burning lots of gas..? :) The Constantinesco Torque Converter ended up pulling trains in Romania btw. It's well worth 'getting it'. Who can claim 100 mpg of gas at 38 mph (61kph) from a 5.58 hp engine running carbs and probably magnetos..? Especially with 1924 aerodynamics. Sounds 'pretty efficient' to me! :) https://simanaitissays.com/wp-conten.../car.jpg?w=547 |
It was rubber vs steel wheels. __________________ That pendulum setup seemed awkward for a small car. How big are the pendulums for a train? I compare to the internal planetary two-speed transmission: ecomodder.com/forum/showthread.php/hub-motors-41562 |
If you look at the 1st link you will see very compact cylindrical setups attached to propellers and such. George Constantinesco: Inertial Transmission (US Patent 1591471 etc) There's still a lot of 'shaking a weight' going on which probably led to metal fatigue and bearing issues. Nowadays we have carbon etc fiber and... cough-cough... way better lubricants. There is also a bit of more recent interest: https://www.ijrte.org/wp-content/upl...1565055216.pdf https://www.researchgate.net/publica...tural_Tractors Then there's this to consider: https://www.youtube.com/watch?v=N-JK...WDTJR&index=46 ?!... :) |
