Rear diffuser angle
Is there an ideal angle to try to get? What angles do what? Like do steeper angles tend to cause more downforce and drag than shallower angles. Just trying to get an idea of what to do before I start trying to set up templates. Seems that all the diffuser info I keep finding is aimed at the racing folks that want more downforce. Downforce in the rear to me seems that it would cause drag or vacuum. Obviously what im trying to avoid.
There are optimal angles but everything affects to the results. First you should decide will you begin your diffusor before or after rear axle. If I remenber correct,
Before rear axle the optimum angle was 3-4 degrees After 6-7 degrees Max is about 10 degrees and after that you make lots of downforce Please correct the values who have the huchos book on their hands... |
This is an after thought related to the same topic. With the benefits of boat tails and reattaching wakes and such, is it safe to conclude that a good diffuser is more important than a front belly pan? Seeing how the wake seems to be more important than the air the vehicle hits.
As was stated above, you must have good flow coming in to get good flow going out, so belly pans are your friend. Also, Hucho does not discern between sedan or station wagon, it's just for an underbody. |
Diffuser angle
Reviving this old thread for a question. I read the image below to mean that the most advantageous angle for my rear diffuser is about 4* or slightly less, since I am starting at about the rear axle. My question is how do I judge measure the angle I accomplish reasonably precisely? EDIT: maybe go to my favorite flat spot, park, and use a level to judge the ground and a "quick square," such as this one, to judge the angle? (I have never laid my hands on a "quick square" but a neighbor friend might have one I can borrow). I really have no idea, so maybe I'll just give it my best guess.
http://img72.imageshack.us/img72/4629/venturism8.jpg |
precisely
*You should have 300-lbs of ballast in the front seats so the car will have its 'driving' inclination *Locate the spot where your diffuser will begin *Measure its elevation above the ground *Then measure back to where the diffuser will terminate to get your horizontal distance,your 'run.' *If you have a scientific calculator,you can use the trigonometric function to get your dimension multiplier *If say,you do use 4-degrees,enter: 4 tan,to get 0.069926. *If you multiply your 'run' dimension by this value,it will give you your 'rise' at the back of the diffuser for 4-degrees. *This will be the exact distance above your original starting elevation for the rear of the diffuser,to get your 4-degree slope.:) |
dispensation
Did the calculation and posted results here. I only need 1.99 or 2.098" rise to get 4* depending on the legnth of the run. Pretty nifty simple calculation. This would have been the way to learn math back in school. If only my trig teacher had known or cared... if only I'd had the sense or luck to see the purposes I might love.
There are also apps for your phone that can "solve" triangles. Obviously you need to enter a few variables, but they will usually give you the types of answers you are looking for without having to know or remember any bit of trig. :) I myself am using Triangle Solve for the iPhone.
I completed a version of this diffuser this summer. Thanks again aerohead. Hee is a link to my pics on my mod thread:
http://ecomodder.com/forum/showthrea...tml#post521175 |
