Rear Wheel arch ducting to rear to minimise base drag??
I've been looking at what to do with the rear end, being a solid axle 4x4 makes it hard to do the rear undertray/diffuser because of axle movement & towbar position & it is also hard to close off wheel arches to underside. I have read that the wheel arches develop pressure at the top and need to be ducted, and even more when I do the covers. Looking at all the mechanical mayhem in the area, there are large cavities going to rear of vehicle so I removed rear step today which has opened two slots about 1.5" high and about 3' long one between body and chassis crossmember and a lower one between chassis and tow bar. Before that the air from underneath was only exiting below towbar, the higher exit now is about 8" higher.
Will this help fill the vacuum at the back and reduce drag? I went for a drive and it feels better, but you know how placebo works. I am looking at designing a new rear bar & step, so want to begin the basis of a Kamm back style with it. The current bumper sticks out about 3" either side so if I taper the new one in from the wheel arch to skimm the body corner, it comes in at about 15 degrees and taking that line back about 6" should take about 8" out of the width at that point. If I duct into the lower portion of the rear end, what effect will there be on the rear drag? |
Rear end of what?
Suggest you enter your vehicle details in the garage, so they appear below your username when you post. That way we automatically have the context/details of questions & comments. |
Done, entered into garage.
Basically it is a big SUV type, wagon body, sitting on a steel chassis, running on solid axles at both ends. The axles articulate quite a bit when off road, so getting a continuous undertray set up is difficult. I've been looking and researching a lot on the wheel covers & skirts, but quickly realised anything done on the rear wheels needs to tie in closely with the rear work on the vehicle. |
Of course, every vehicle is different. I do recall reading that Mercedes ducted the rear wheel well area through to the edge of the rear tail lights, claiming the pressurized air promoted cleaner flow separation & drag reduction. (If you search, you'll find a thread about it here.) But the improvement is going to be so minor, and so difficult to test, I'd be concerned with the lower hanging fruit first. Quote:
Salient line from the PDF:
Thanks for the replies, was hoping for yes or no answer, rather than maybe or maybe not.
Cd - I did read that UK study, and also found some others related, but not really much detail and they were not done on a moving ground or tested in real world, so not really conclusive, but still a possibility. Metro MPG - I will look up the Merc discussion, but about the 15 degrees being too sharp, as I understood it an overall between 12-22 degrees is suitable depending on other factors, 22 being doubtfull if other factors are not supportive. Where I say 15 degrees, I'm not talking a sharp edge 15 degrees, it would likely be about 6-8 inches transitioning from 0 - 15 degrees, so a curve leading into the straight, is this ok or have I missed something fundamental in everything I have read here. I have put the spare back on the rear, std factory position, just looking at ways of filling & disturbing that vortex, FE is still trending down, last fill 9.87l/100km, recent average since mods began, down at 10.5l/100, average prior to mods 11.4l/100, so all still moving in the right direction. |
FYI, the Merc ducting to the tail light was very similar (though more subtle) to the ducting modification in the PDF link, above.
As for tapering the bodywork, glad you're thinking curves rather than just angles. 15 degrees in 6-8 inches seems like it may be too much, too soon. FYI, attached flow at 22 degrees is only achievable as the ultimate angle/tangent in the curve for a given shape. If you get to 22 degrees (or any angle) "too soon", separation occurs. Have you seen this thread? http://ecomodder.com/forum/showthrea...rt-c-9287.html PS - congrats on the fuel economy improvement so far! |
Thanks,
Yes I have read the template thread, and have a read of most threads on a daily basis, but the deeper I go, the more questions arise, seems there is more than one way to skin this cat. I think my FE will crack the 10l/100 mark, but no declaring that till I get a few more tanks through. |
MetroMPG
Found that Merc thread with the tail light ducting below, http://ecomodder.com/forum/showthrea...trol-6075.html The tiny slits they have would not be capable of any serious ducting, I think thaey were there primarily to give clear seperation at the body edge, like vortex generators, so rather than putting a sharp edge on the lights like they are doing moreso now, they chose to eject some sharp straeams of air, which simulate a sharp edge and give clear seperation of air from the body. That's my interpretation. My direction would require quite a bit more volume, to help drop pressure at rear and and hence reduce drag, more like the uk study linked in one of the posts above.. |
ducting
Auto makers have attempted to make the wheel cavities air tight,other than for brake cooling and engine bay hot air extraction.
If air can essentially 'pool' inside the wells,the outer airflow will skip over the stagnant air as a flat pebble on water.Some rear deck spoilers are designed on this principle.Holden aero-modded a Commodore for racing,using such a 'birdbath' rear boot. In addition,if you rob air from the 'outside',you're taking energy away from air which already has a direct path to the back,jeopardizing the boundary layer and setting yourself up for even more separation than you already have.Which can only increase drag. Remember,streamlining is a lot like algebra.Whatever you do to one side of the equal sign,you've got to do to the other. |
Aerohead,
Thanks for the response. Got the algebra thing, just trying to work out what I am actually subtracting from. If we want to seal up the wheel arches as much as possible, why did the honda taper out the rear of the front wheel arch on the insight, is this just for the air turbulance from the ground contact point so it can rejoin the side air more smoothly? If this is an appropriate mod for the front, is it also an appropriate mod for the rear? The UK study indicated that there was a pressure build up at the top of the rear wheel archs, although they did not test this in a moving ground wind tunnel. I was planning to put full rear wheel skirts on, was just concerned whether I should address the wheel arch pressure/ducting issue. Oh, so many questions. |
He's saying that when the wheel arch is closed like stock the air will form a sort of bubble and under-body airflow will treat it just like a "phantom" belly pan. Letting air out of this bubble somewhere else will just direct air into this high drag area, increasing your overall drag.
What comes out, has to go in. And "in", in this case, is a very turbulent area. Honda's Insight and more notably Ferrari's 250 Testa Rossa have rounded the rear of the front arch to facilitate better flow in this turbulent area. My advice is to install flat wheel covers, block in the front and top of the wheel gap, and leave it alone. Using a rear wheel skirt will help you a bit but rounding out the edge of the arch is probably a waste of time afaik. You could attempt some front wheel skirts but I'd be more concerned about a boat tail at this point. Low hanging fruit. I hope that helps. :) |
Yeah it does help, I did understand where Aerohead was coming from, my confused comment was more of a generalisation about how many different concepts are out there and how to choose whats best. Thanks for your opinion on the wheels as well. I have temp partial front wheel skirts on currently, as per a previous thread, am happy with the basic idea, but longer term I think the front wheel area could actually benefit from a vent which can be done, in my case the actual plastic guards stick out about 2" from the body and with a bit of redesign a vent could be put at the rear of that guard, which would allow the vent air to run along the channel formed between the lower body and top of sidesteps as it merges with the rest of the side air. As said I plan full rear skirts and am letting go of the venting idea, too many unresolved questions there. I appreciate your comment on the low hanging fruit, but at the moment I am investigating a wide range of ideas to get a picture of the final product, then work towards putting it all together. Funny you should mention the boat tail, I have been looking at how to do that as well, but starting another thread for that one. Thanks to everyone for their comments, I really appreciate all the help and I feel like I am starting to get a much better handle on all this aero stuff, but still lots of study and work to do. |
Some or maybe even a lot of aero sure seems counter-intuitive at first hence the general mystery and confusion.
Like anything, you need to imerse yourself in it for a while and then it start's to come together, it's all logical, you just need to find the right perspective. Slowly getting there. |
"Doing" helps too, as you start to really understand it in three dimensions.
It might be worth setting up a build thread to consolidate stuff into one place :) |
Yep, will do as soon as I can take a breath & if I run out of duct tape.
wheel wells
On the rear,they're not really 'aspirated' as up front so,say on a rainy day,you won't see a 'jet' blast from the rear as you do see up front,and the radius would be overkill.With wheel skirts,they would be superfluous. If you'll do the skirts the pressure issue will probably be moot.I do think they should have done the test with a moving ground plane. The volume of the house affects drag although that would be a very challenging modification. And yes,the more answers we get,the more questions arise.:p |
Nevermind, i suppose that will just mean a bigger gain, particularly when I cover the rear wheel arches. I will do the vent on the rear edge of front wheel arches, as there is an opportunity, and it would look much beter that just being curved back to the body. Thanks again for your input. |
