Reattaching wake and drag penalty
I'd like to ask all of you here about what kind of drag penalty that results from using a spoiler ( or trunk lid ) to reattach airflow on a car with a rear taper that is not the ideal angle.
http://farm4.static.flickr.com/3113/...503bc37a_b.jpg Note that the Camaro had a worse Cd without that spoiler, even though it kicks up at an angle ( The same results can be found in upward tilting spoilers on the R&T project cars - the Crisis Fighter Pinto and Crisis Fighter Datsun Z car. http://farm3.static.flickr.com/2284/...8c695430_o.jpg On cars such as this Fusion, if you follow the roof line out at a 15 degree angle, you eventually meet up with the edge of the deck lid spoiler. I am guessing that this acts as a way of grabbing the airflow and bringing it back into the ideal trajectory. For those folks on this site not willing to create a huge boat tail on the end of their prized car, why not create a large shelf spoiler that is easily removed ? From the examples above, it seems as though adding a spoiler can sometimes have a drastic reduction in drag.... but what are the penalties ? Thanks ! |
Isn't that something? I've been thinking of this exact thing now, ever since Metro put up that F150 aero thread.
I've been outside pondering the best aeromods for my Tempo. Even have a crude mock-up on it. Boattail doesn't appeal to me for several reasons. No top chopping; I don't want to drop the seats onto the floor because I want to retain rear seat functionality too, and I need the headroom. No fastback window and bodywork; too much work for too little gain. And so on... until I settled upon the notion of a "Bonneville Style" spoiler remarkably similar to the one pictured on the Fusion! So I've been reviewing my Hucho book and surfing for aero articles. Yes, that's why my recent posts reference some Hot Rod magazine stuff. I want my spoiler to go out rather than up to achieve the imaginary 14 deg drop from the roof. This minimizes the area of the body that leaves a wake zone. The Camaro would have been even more slippery with a "Bonneville Style" spoiler. |
Yo
Frankie, whyoncha extend it all the way out and tilt it down like the trunk on the ESX ? Not only would the airflow connect, but it could follow the angle downwards and make your wake even smaller. Your back glass is really steep. I wonder if a small lip spoiler would be helpful in convincing the air to meet the big spoiler without too much turbulence. http://farm4.static.flickr.com/3437/...7a64921158.jpg |
I thought the reason a spoiler (can) reduce drag on (some) so-called "fastbacks" is that the lift generated by the attached air following the slope of the body created vortecies at the sides of the roof...and at some angle the benefits of filling in the vacuum behind the car (with air coming down over the fastback) were outweighed by the drag penalty of the vortexes (see, I can spell it either way). I don't have my Hucho handy, but I'm surprised the optimum angle is as low as 14 degrees...not the first time wind tunnel results have surprised me, but still.
On a lot of sedan race cars we add spacers under the hood hinges to let the high pressure area in front of the firewall loose. It often ads 4 or 5 mph down the straightaway. Anybody tried it for mileage?
Dave |
Ummm... what? :confused:
I'm told what you'll have by raising the rear of the hood is flow into the engine compartment. |
I need to think about how far out the back I'm willing to go with these appendages. |
I found a wedge-shaped spoiler in a book and posted the translation here. I guess it's the next best thing to a full length roof extension.
penalty
I'm guessing that the Fusion is FWD? The Camaro is RWD,yes? Since these are both Bonneville cars and they're running parachutes,then they're both looking at at least 175-mph.Some Bonneville cars have enough horsepower to spin their tires when they hit an "aerodynamic wall" ( the car has more power but cannot attain higher speed due to air drag) and can drift into a most dangerous spin.--------- I think these spoilers are a compromise between drag reduction and downforce and not necessarily the best designs for "street" cars.------------------ Any design which has an exit tip which falls along Kamm's roofline profile,whether an up-kick or straight back,will both do the job.------------- All spoiler setups pay a mpg price due to the attached vortex directly above them since the air is making more than one "pass" over the body.And you have to pay for this circulation.-------------- If you do the straight back shelf be mindful of unsuspecting pedestrians walking up from behind.Maybe cushion the trailing edge as Porsche did with the Carrera Whale-tail.------------- I'm partial to Ford's bi-wing spoiler which appeared on the Sierra concept car and Merkur XR4Ti.It gets the job done and with less drag.
Hmmm... good idea. I will make mine razor sharp.
Kamm extending spoiler
This thread has piqued my interest because I have been playing around with an extending Kamm-rear spoiler idea. The critical downstream rear angles could always benefit to a long-tail configuration. The idea is very similar to reconfigurable/extending airplane wing flaps. The move-able wing extend & become flush/fixed to the fastback surface & additional wingtips deploy downwards to clean up some side flow. I've considered these add. tips to deploy outside the rear light assembly but would compromise the safety equipment. The wingtips always could be made w/ clear polycarbonate to passed safety reqs. Lower speeds & parking maneuvers needs retracting the wings. 'Active' wing flap angles become too complicated.
Also another idea, a model specific (Prius 2010) rear wheel covers extend to very clean flows sharply detaching at the bottom & rear edges... http://i429.photobucket.com/albums/q...extensions.jpg |
OK, this is something I'm working on for my Escort. And one of the limitations that I have is that TOWMBO will not tolerate any public display of eccentricity. :eek:
So, a belly pan is acceptable, but a boat tail is not. Wheel discs are borderline acceptable, rear wheel pants are clearly not. So, I might get away with vg's, but... So, my back glass is ~30* from horizontal, and a line from the back of the roof line to deck height at 14* says I need a 8"+ shelf attached. :( What does the collective mind know about the +/- of rear window dust deflectors? I know, those are usually only for "wagon" backs, but a deflector with an included arc of 25* would certainly be a place to start. Yes, this would cause lift at high speeds, but at econ speeds, what would be the down side? Would a smooth deflector blade cause more drag than 8 vg's across the back edge? |
deflectors
Cd: "damned pressure bubble"... thanks for the laugh. :)
"Out damn bubble, out!" Seems to be common running joke 'round these parts...so has anyone done the obvious & 'attacked' it with something like this...
http://www.team-bhp.com/forum/attach...s-dsc02307.jpg Looks like bug deflectors moved backyards but smoke tests & tuft testing would be interesting to see. |
Both Aerohead and Basjoos created air deflectors for their wipers. I'll let them eloborate on any gains. I tufted my car and noticed that the turbulent bubble on my car only extended a couple of inches past the arm of the wiper. http://farm4.static.flickr.com/3280/...d8d709c8_o.jpg . Also look here. This is a very good article on tufting the wiper area : http://autospeed.com/cms/title_Silen...5/article.html |
I added a small lip spoiler to the edge of the roofline on Franks' car due to the fact that his back glass has such a steep angle. His car is almost like a hatchback with a trunk. ( I hope I understand your question. ) |
Dave |
short Kamm
"Bonneville-style"-origins?
I was data mining for spoiler info and crossed paths with the old article by CAR and DRIVER on the 'Crisis Fighter Pinto'.
In the article they mentioned how,in March,'74,Porsche had already changed the 911 Carrera tested in February,'74,from a 45-degree upswept rear spoiler,to a very long nearly-horizontal wing-like surface with capping plates, extending from the decklid. They surmised that the new spoiler for this 911 Carrera RSR provided the same downforce as the Carrera but without the drag penalty of the steep up-sweep. The RSR finished 2nd at Le Mans,won at Daytona,won the Trans Am Championship,and also won the Targa Florio that year. ================================================== ======== I do not have a 'true-length' photo of the car,so I can't say how far the spoiler extended,but it was VERYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYYY long! No risk to pedestrians though as this was strictly a full race car. -------------------------------------------------------------------------- I do not have a large dry lakes racer database but this 1974 RSR may be the progenitor of all the 'Bonneville'-type foils. |
911 spoilers
3 Attachment(s)
Aerohead, are these the 911 spoilers you refer to?
street vs race
I've only seen the RSR in a book. |
File:Porsche RSR am 19.05.1974.jpg - Wikipedia, the free encyclopedia |
Shooda just stuckit on the roof above the window!
that's it!
pretty loooooooooooooooooooong!
With a 6-cyl engine cantilevered back beyond the transaxle they might have needed all that downforce.'Don't think it's a good fit for us. Maybe inverted liquid-fuel rocket boosters are next for Porsche?:eek: |
They also added another rear window, stacked on top of the original but with a shallower angle. That supposedly helped with both downforce and drag. And the front splitter was required to give reasonable aero-based grip at the front to match that at the rear.
-soD |
They did all kinds of things with the 935 once they picked through the rule book. Like they found they could raise the floor (originally written in so front-engine cars could pass the exhaust pipe under the side or some such) so they raised the whole thing. Then lowered the car back down again so the floor was at the original height. Result: Lower car overall, lower CG, etc. The engineers worked that rule book over with a lead pipe! ;)
-soD |
good eye!
Oh, I didn't get that from the picture. :D That's from reading endless articles about the 935 racers over the years. I'm a wee bit of a Porsche nut, you see... (Just got back from dinner in the wife's 911SC!)
-soD |
nut
Shift gates a bit mysterious but other than that,real driving pleasure! |
