Old 12-27-2012, 07:58 AM   #1 (permalink)
Lump - '94 VW LT28 Doka
Vw lt28
I thought I already posted an intro but I can't find it so here we go. I brought over an LT28 from germany in 2009. It currently has a 2.4L straight 6 diesel. The same one used in lots of 80s Volvo cars. Currently I get an average of 10L/100km (24gpm) on the 1 tonne truck. From my British friends, this seems about average.
The plan is to put in a M-TDi from a 03 Beetle (I want the truck to keep running if the electrics go out for any reason, plus it is just simpler). We are slooooly rebuilding the engine and adding a quattro tranny so I can match the trucks rear drive. I would rather drive the front wheels but the mods would be way too extensive for now. We made some changes to the tranny so the front take offs will be engaged only when in neutral and I plan to have electric motors to drive the rear wheels. I haven't figured out the throttle yet tho...
The ultimate goal is 2000km from a 70L tank but I have no idea if I can achieve this.
Mike
Name:	007.jpg small.jpg
Old 12-27-2012, 02:21 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder !
3,5 L/100km is ambitious to say the least !
Even with (partial) electric drive - though obviously with more batteries you could lower the diesel consumption.
With 2 power sources, you're always carrying one too many - and the associated weight of the system, here combined with the added drag of the quattro drive.
Still : good luck with the project !
Old 12-27-2012, 06:19 PM   #3 (permalink)
That sounds like an interesting project.
Old 12-27-2012, 06:47 PM   #4 (permalink)
I did a test with this truck which was to drive 200km with nothing in the truck other than me and my girlfriend, then I filled the tank again and drove another 200Km with 300kg in the back. Same road, same type of hills, same wind direction (as much as possible) and had the same fuel economy. It would seem that the outdoor temp has more to do with the economy as the weight so I think that the weight of batteries and motors won't be a major factor. The drag from the tranny may be a different story but we will have to see.....stay tuned.
