EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Relationship between body pressures on the rear panels and the base pressure (https://ecomodder.com/forum/showthread.php/relationship-between-body-pressures-rear-panels-base-pressure-38949.html)
JulianEdgar 12-29-2020 12:00 AM
Summarising what the experts told me.
There are two main theories used to describe the relationship between body pressures on the rear panels (eg side panels) of a car and the base pressure. One is the jet pump / boundary layer thickness approach, and the other, the trailing vortex approach. Sometimes, the approaches are combined.
Jet pump and boundary layer thickness
This is based on Hoerner’s ‘jet pump’ idea. That is, the flow of air as it leaves the car forms a tube of moving air (the ‘jet’) that surrounds the base area. This moving air mixes with the dead air behind the car and tries to pump it away i.e. entrain it. This reduces pressure on the base, creating drag.
If a thick boundary layer (that is, a layer of air moving more slowly than the freestream) exists on the rear panels of the car, this creates an ‘insulating’ layer between the jet of fast-moving air and the dead air. Thus the thicker the boundary layer, the greater the base pressure, giving less drag.
A thicker boundary layer occurs when there is an adverse pressure gradient, and so there will also be higher pressures on the rear panels when there is a thicker boundary layer. But is the thicker boundary layer caused by the higher pressure or vice versa?
Adrian Gaylard (Jaguar Land Rover) commented:
Which is the chicken and which is the egg? As is often the way with continuum mechanics, it’s a bit of both I think.
Trailing vortices
Different body shapes develop different trailing vortices. Wake pressures reflect these different vortices. For example, a squareback shape has little trailing vortex development and will have pressures on the rear panels that are similar to those in the wake. Conversely, fastbacks and notchbacks will have base pressures that are lower, as the base pressure is strongly influenced by the vortex development.
Thomas Wolf (Porsche) commented:
It is understandable that with a squareback ("shoebox") the pressures on the side surfaces roughly correspond to the base pressure, while this is rather not the case with the fastback. In other words, there is no clear correlation here. Rather, it is a combination of vehicle shape (upper/lower contour, side contour/taper/boat-tailing, cross-sectional shape) and the vortex formation that determine the pressures on the individual surfaces and the base pressure. Thus the flow patterns in the wake result from these relationships and not vice versa.
Combining these approaches
Rob Palin (ex Tesla) combined the above approaches in an earlier communication with me:
There's certainly a complex trade-off when it comes to reducing wake size, and there are strong influences from the surface boundary layer thickness, absolute static pressure, and static pressure gradients at the point of separation. Thick boundary layers and/or weak pressure gradients generally mean weak vortices at the sharper separation edges, and higher overall base pressure.
I asked Rob to expand on this, and he said:
The mechanism here is mainly to weaken any vortices that form around the trailing edges of the vehicle body. I'm sure purists would hate this, but I would describe it as being that thick boundary layers lead to 'fluffier' vortices, which have less intense velocity gradients, thicker cores, and generally much higher pressure. These vortices both pull less hard on the rear-facing surfaces, and burst sooner, meaning that they don't persist for long in either time or space. In aero-acoustic situations that's a bad thing, but for drag it's good.
Behind this is the way that vortices are born from the sudden release of the pinned/slow near-surface air when the air away from the surface is travelling very quickly. This velocity gradient, and the intense viscous shear it causes, rolls the air up into the vortex tube. The steeper the velocity gradient, and/or the more abrupt the disconnection from the surface, the tighter the wrapping of the fluid layers, and the more intense the vortex. Tighter vortices get to lower pressures, and that pressure kind of 'pollutes' the wake around it, lowering the overall pressure.
From the pressure gradient side, as long as you have attached flow, you are aiming to reduce the velocity gradient normal to the surface. You can do so by reducing surface curvature. A secondary option is to try and slow the air down as much as you can before any sharp separation edge, so that the velocity gradient between streamwise flow approaching the edge, and the recirculating flow around the corner of the edge, is minimal. This again leads to less intense vortex generation.
Pressure testing
So it would seem that from either the jet pump / boundary layer thickness idea, or the trailing vortex development idea, having pressures as high as possible towards the rear of the car on the side panels is a good thing. (Remember, they’re still below atmospheric and so it’s sometimes easier to think of them as being “less low” rather than “high”.)
Adrian Gaylard:
This is essentially what is implied by the “pressure recovery” explanation. If you boat tail or extend the flow surface with a spoiler both are generating a thicker boundary layer at separation along with higher pressure.
So anything that you do that increases side pressures is likely to be a good thing. That’s what happened with my Edgarwit air curtains on my Insight, and with my temporary covering of the rear wheel arch with a spat on the Mercedes.
But why do these modifications increase pressure? My guess is that they reduce separation, so leading to the development of a thicker and more stable boundary layer, indicative of a higher pressure (and again there's that chicken and the egg).
deluxx 12-29-2020 02:19 AM
Since I have no tech literature on this subject, and haven't personally tested it, there's a fair amount of misleading information in earlier posts...
aerohead 12-29-2020 12:37 PM
increase pressure
Trailing vortices
Pressure testing
Adrian Gaylard:
1) Streamlines are isoenergetic.
2) They all contain identical kinetic energy.
3) Velocity can be swapped for low pressure or vice versa.
4) Any cleanup at the front will allow more turbulence-free, kinetic energy to survive to the aft-body.
5) Moderate pressure increase along the side profile will ensure flow attachment, and pressure regain, as the flow decelerates along the sides of the decreasing cross-section, as well as up top ( hopefully ).
6) If flow remains attached all the way, it will be at its slowest velocity, highest pressure, and base pressure will mimic that at the separation line.
7) The presence of the turbulent boundary layer allows for the momentum transfer from the local streamline, down to the lowest strata of the TBL, adjacent to the body 'boundary,' holding it in place.
8) The thickness of the TBL is essentially meaningless, as long as it is present.
9) The shape of the body profile makes or brakes TBL attachment.
10) That's why they call it 'profile' drag.
JulianEdgar 12-29-2020 03:03 PM
Well unfortunately that isn't what the experts say - including one of your favorite references, Hoerner (section 3-19).
Also refer to https://www.researchgate.net/publica...r_Modification - a paper that specifically addresses the connection between boundary layer thickness and drag.
Again, what you say simply isn't supported by the experts.
aerohead 12-29-2020 03:37 PM
experts
1) You have Hoerner's book?
2) You understand that jet pumping action has to do with 'basic, simple, bullets and artillery projectiles, in free-flight? Not an automotive bluff body in ground effect?
3) A streamlined basic body of Cd 0.09 will have the thickest TBL, yet the lowest drag.
4) Can you clarify your remark?
JulianEdgar 12-29-2020 03:40 PM
1) Yes I have Hoerner's book.
2) You didn't read the paper I cited? Adrian Gaylard suggested it to me as being highly relevant to cars.
3) That's right - you don't seem to understand the original post I made in this thread?
4) Which? Your comment that "The thickness of the TBL is essentially meaningless, as long as it is present." is not supported by the experts.
aerohead 12-29-2020 04:36 PM
highly relevant
1) I have Hoerner's 1951 book.
2) There's nothing about jet-pumping action in the chapter on motor vehicles.
3) Only isolated projectiles.
4) What changed that is 'highly relevant'?
JulianEdgar 12-29-2020 04:54 PM
I am not going to continue joining the merry-go-round.
I am happy to follow the expert advice I receive from the world's top car aerodynamicists, to read the papers they cite, and to read the textbooks they cite.
I pay attention to what professional automotive aerodynamicists say and write. You refuse to do so - and so continue to have a weird set of aerodynamic theories that don't match reality.
That's fine - so long as you don't mislead others.
aerohead 12-29-2020 05:33 PM
I am not
That's just it. This is the modus operandi.
Volunteer nothing in your own tongue, such that it's crystal clear, or not, that you understand the topic.
How would you know if anyone's been mislead or not? Nothing you've shared so far overturns anything. Perhaps it obscures.
There's a dividing line between 'basic' and 'complex' bodies. If you work for the Paris Dressmakers, then perhaps it IS a 'black art' to squeeze anything out of something like a Porsche Macan.
JulianEdgar 12-29-2020 06:14 PM
What an odd thing to write.
I have written well over 100,00 words - two whole books, no less - on modifying and testing car aerodynamics - in "my own tongue".
But you seem to be criticizing me for actually directly quoting experts and text/paper references! Gee, that would never do, would it?
How quite bizarre.
JulianEdgar 12-30-2020 03:40 AM
I just saw this.
As with Aerohead's comment on the thickness of the boundary layer being of no consequence, it is also wrong.
If you wish to see this for yourself (anyone) just measure some pressures on real cars on real roads. On many cars, as indicated by the experts quoted above (surprise, that!), base pressures do not "mimic that at the separation line".
Here's a real life example from my measurements (side/wake and then centreline/wake):
https://i.postimg.cc/ry72cCCX/Merced...e-and-wake.jpg
https://i.postimg.cc/3rXFJ328/Mercedes-centreline.jpg
...and from car company measurements (centreline/wake):
https://i.postimg.cc/nr2mKc1q/RX7-lift.jpg
It's a good example of Aerohead just repeating what he has said before, and utterly ignoring any credible information that doesn't match his existing beliefs.
I know it's quite silly of me, but I was actually looking forward to Aerohead commenting on this thread, and potentially building on the latest information from some of the best car aero experts in the world. Especially, when there is so little on this specific subject in the textbooks - and it so strongly relates to our number one topic of reducing drag.
But I should have guessed that instead he'd just repeat same-old, same-old, complete with mistakes. Then, subsequently, defend those mistakes to the death, irrespective of any evidence brought to the contrary.
[Shrug] For everyone else, look and learn - I certainly am.
(And from Adrian Gaylard today in response to a last question from me:
Classically we’d think of the pressure gradient driving the boundary layer, which is essentially the way adverse pressure gradient driven separation is described. But energy loss at the surface generates the boundary layer. There’s usually more than one thing happening.)
aerohead 12-30-2020 01:31 PM
no consequence
Originally Posted by JulianEdgar (Post 639492)
I just saw this.
1) The Mercedes is not a 'full' body, with respect the 'entire' body it's derived from.
2) Your measurements, while representative of the given length of the Mercedes, would, in no way, reflect the context within which my comment was prefaced.
3) If 'half' of the Mercedes weren't missing, you'd be left with the thickest boundary layer and lowest drag, represented in the pressure profile of the missing body.
4) 'many' cars does not constitute 'all' cars. Measure a 'Kamm-back' and report back.( Renault Vesta-II, Mercedes-Benz Bionic Boxfish, Mercedes-Benz IAA, with tail extended etc..)
Is Gaylard going to retract his ' flow separation due to the adverse pressure gradient' quote from page- 59 of his Doctoral Thesis?
Viscous shearing forces, fed by momentum interchange from the local streamline does generate the TBL. That's classical boundary layer theory.
An EcoModder's best dream come true would be to have the 'BIGGEST' boundary layer imaginable!
JulianEdgar 12-30-2020 03:00 PM
What, so it is actually a theory that applies only to three cars in the entire world? Sorry, I would have thought we're interested in theory that applies to the cars we're working on - you know, the ones we're modifying.
Yet again, an Aerohead theory that doesn't match reality.
aerohead 12-30-2020 03:46 PM
reality
You used my material out of context and I was simply clarifying the situation, adding the proper context.
I just added SAE 2020-01-0673 in its own thread, which illustrates 'entire ' bodies, which begin in their entirety, afterwards truncated to a 'practical' length if so chosen.
Whenever I see a vehicle for the first time, this is the context in which I experience them.
You may come to realize that many 'cars we're working on' respond very favorably to the 'theory.'
JulianEdgar 12-31-2020 04:58 PM
Rob Palin had a lot of interesting things to say regarding this topic (so now all my experts have got back to me).
In short, he took elements from what they other experts had said, and then fleshed them out in more detail.
My summary is this:
1. There is no simple, pat answer as to what influences base pressure on different cars.
2. Therefore, without testing, you're working very much in the dark as to the effectiveness of modifications.
3. Higher pressures on the side of the car, especially towards the rear, will likely increase base pressure. (And my testing clearly shows that higher side pressures occur with better flow attachment.)
4. Thick boundary layers towards the back of the car will likely increase base pressure.
aerohead 01-06-2021 11:35 AM
summary
My summary is this:
1)
A) ' it is possible to relate geometry to flow pattern clearly for the fastback and the squareback.' Hucho, page- 155
B) ' On a prismatic body, the base pressure in real flow is dependent upon the fineness ratio.' Hucho, page- 140
C) ' The base pressure also depends upon the angle at which the flow separates from the contour.' Hucho, page-141
D) 'With a long diffuser, a notable reduction in drag can be achieved with a very small angle.' Hucho, page- 144
2)A) ' The shape for minimum drag can be calculated for a given fineness ratio and volume, and the theory can be used to translate results from scale models to full-size bodies.' Hucho, page- 106
2)B) ' Basic bodies with drag figures of less than 0.15 can be ... used as initial shapes for shape optimization.' Hucho, page- 198-9
2)C) It's conceivable that a template may allow for zero ' changing the detail in question until the flow no longer separates around it.' Hucho, page- 124.
So in regards to your comment, I could not disagree more.
3) absolutely!
4) If the aft-body cross-section contracts progressively in the flow direction such that only a 'moderate' pressure increase is produced, the boundary layer will be protected from separation, flow will remain attached for the entire length of the existing body, turbulent boundary layer will be the thickest, and pressure will be the highest possible, when separation does finally occur at the trailing edges; yielding the highest base pressure.:thumbup:
JulianEdgar 01-06-2021 05:38 PM
Originally Posted by aerohead (Post 640009)
1)
3) absolutely!
I looked up each of your quotes and they're generally either taken out of context, refer to 'shapes' (not real cars), are a bit simplistic or are rather tortuously applied to support your theories.
All the professional car aerodynamicists that I asked to comment on the topic of 'what influences base pressures?' on real cars said there was no single answer, and the influences of various mechanisms were poorly understood.
My summary thus remains:
aerohead 01-06-2021 05:54 PM
context
Thanks for the response. The clocks about to run out here, and no time to cover all the items. I'll be back Friday, with a fresh 'clock' and will get back into it. Thanks again, see you Friday.
