EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Removable lexan grill block (https://ecomodder.com/forum/showthread.php/removable-lexan-grill-block-13228.html)
carbonaltima 05-13-2010 12:59 PM
I have some lexan lying around and was wondering if anyone has made a grill block. i would it to be removable also. Has anyone done this. Any tips. I drive a 2000 altima i don't know if that helps but maybe someone has some mounting techniques that i can use. thanks.
dcb 05-13-2010 01:29 PM
it should be fairly easy to plug up the big holes in the front of your car with lexan. Just hold the clear lexan over the hole, and trace out the hole with a marker. Then cut out your plugs with a jigsaw.
I would probably paint the backside black so it is shiny black on front, rather than let it get grimey looking, if you worry about that sort of thing.
Also several dabs of hotglue or silicone can be pretty easy to remove/clean up. Or a couple small holes in the lexan and some black zip ties/bits of wire will probably suffice.
PaleMelanesian 05-13-2010 01:49 PM
I like the idea. ;) I used plexi instead of lexan.
http://ecomodder.com/forum/showthrea...sian-7329.html
Aero mods - new grill block and wheel covers - CleanMPG Forums
http://www.cleanmpg.com/photos/data/500/quarter.jpg
