removable weatherproof caulking?
so I had a bar conversation with someone a while back and he was talking about this caulking you can put on your patio doors/windows/etc that give a weatherproof seal (IE for keeping out the cold) that can simply be pulled off come spring time. I've looked around in the homedepot/lowes/etc and I can't find what he may be talking about. Anyone here of this??
bensenvill -
How about the RTV silicon that dries clear? I think you can just peel that off without damaging anything (may take some paint with it, oops!). CarloSW2 |
this is the stuff you want .. its ez to use and remove
BULLDOG SEAL, SIL DRAFT STOP TRANS 300ML Draft Stop * - A transparent, waterproof, energy saving product for indoor and outdoor use, applied around windows, or areas with air penetration * - It will form a clean transparent seal that is easily removable when required |
If you prep the surface by cleaning it thoroughly, then wipe it with Vinegar, it will stick just fine, and you'll be able to peel it out next year if you want. The ability to peel the caulking out kinda defeats the purpose, though, doesn't it? |
Christ -
I don't know the purpose, but ... in the old daze in winter, it was custom to close off parts of the house and hunker-down next to the stove/chimney. Less volume to keep warm saves on heating fuel. I could imagine a situation where you seal up inner doors in the winter and unseal them in spring. Orrrrrr, you could seal up all windows in a room except for maybe one, and unseal the rest in the spring. Because the RTV dries clear, I was thinking one could use this to seal gaps in the car. CarloSW2 |
Yeah, you can use clear or colored silly cone. If you go to the right place, you can get white (untreated) silicone caulk, and then buy a color pack and mix up the right color for your application. Caulking is part of a brick mason's job... |
WD40 -
CarloSW2 |
Christ -
CarloSW2 |
Latex caulk works well on painted surfaces, and slicks clean.
Silly-Cone works great, too. Never use Urethane. It gets rock hard. Silly-Cone stays flexible, but goes through wicked heating/cooling cycles, and will separate if not prepped properly. Latex cracks if you apply it too thick. Any "gap" more than 3/8" deep needs something as a backer to create a proper 3-sided seal, or the caulk will eventually fail (way before it's supposed to). |
