EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Removing winshield wipers. Big difference in cod? (https://ecomodder.com/forum/showthread.php/removing-winshield-wipers-big-difference-cod-13240.html)
carbonaltima 05-14-2010 01:19 PM
Will removing my windsheild wipers make a big difference in reducing aerodynamic drag?
Daox 05-14-2010 01:20 PM
Nope.
wyatt 05-14-2010 01:59 PM
I put in a wiper block, and it does reduce wind noise, but I run with sometimes and without others, and there is no noticeable difference in FE. The biggest difference is not having air coming in the vents [without the blower on] when driving (great in the winter, not so great when it's 90+deg out).
lunarhighway 05-14-2010 03:41 PM
i think wipers are the last thing you want to remove... on some cars the rear wipers might have an impact, but i think on most modern cars they don't interfere with the overall airflow.
Gasoline Fumes 05-15-2010 01:57 AM
What about cars where the hood and windshield are almost the same angle?
http://img.photobucket.com/albums/09...gonprofile.jpg
I get very little air coming through the vents without the fan running. I don't think there's much of a high pressure zone there. I took the passenger's side wiper off, but I have no idea if it makes any difference.
RobertSmalls 05-15-2010 11:09 AM
http://www.aerocivic.com/imgs/wipers-z.jpg
GasFumes, tuft testing would be really easy to do in the vicinity of your wipers, and you could compare flow across the driver's versus passenger's side.
lunarhighway 05-15-2010 11:59 AM
http://i77.photobucket.com/albums/j5...va_2010_01.jpg
3-Wheeler 05-15-2010 01:15 PM
I really like what Basjoos did on his AeroCivic.
If I were to make a replacement hood for the Insight, this would certainly be done as well.
Jim.
Gasoline Fumes 05-17-2010 09:40 AM
The driver's side wiper parks pretty close to the center of the car. I tried tuft testing with no wipers, driver's wiper and both wipers. All tufts were tight against the glass, with a little more "wagging" on the driver's side. But I saw no difference with or without wipers.
This is with just the driver's wiper, but the tufts looked the same in each test.
http://img.photobucket.com/albums/09...tuftsfront.jpg
hotrodfeguy 05-17-2010 09:57 AM
I like the pic but I think you need a pic for with and without. To see if there is any change.
Gasoline Fumes 05-17-2010 10:40 AM
I probably should've taken pics of each test, but they all looked the same.
