Renewable energy storage scheme.
Here is a storage scheme that parallels the idea of using excess renewable energy to lift large bricks and use the resultant potential energy later.
https://www.fastcompany.com/90261233...edium=referral |
Same concept as using rail cars. https://s3.amazonaws.com/siteninja/m...S_-_101217.pdf Central storage areas would work for highly populated areas. Outside of populated areas, individual systems could be developed. For instance, a chimney like structure could be added to a home with a winch-motor-generator and a large weight. (Concrete or water) Many years ago, I think it was Popular Science. Had a article that proposed putting a large concrete flywheel in the basement of a home for energy storage. > |
I learned about the below a few months ago, similar to as described in the article I suspect. Ludington Pumped Storage Power Plant https://en.wikipedia.org/wiki/Luding...ge_Power_Plant Quote:
Yea, the original concept posted offers a lot of advantages. |
The trouble is in sheer mass that is needed to be transported. Lets say you want to make a cup of tea. To heat cup of water you need Q=cmdT, having m=0,2 kg; dT=85'C;c=4200 kJ/kg'C gives amount of 71400 Joules. Thats equivalent of rising 1 ton concrete block into height of 7 meters!
For any practical implementation you need to literally move mountains. Real time. |
Space elevator and energy storage-
When excess power is generated, reel the space elevator in a bit with an electric motor. To get the power back out, the centrifugal force will spin the generator as the elevator unwinds. |
Very simple physics math tells us this isn't really useful, unless you have something the size of a lake.
Hasn't PGE been doing this for forever at Huntington lake just north of FRESNO?
The lake is full at dinnertime, perhaps 5 ft lower at dawn |
Everything is solar power, including fossil fuels, except for nuclear power (which is supernova power, or whatever mechanism creates the heavy and unstable atoms).
I'm solar powered. Thought about making a tee shirt that said as much. |
To build elements heavier than Te is a process called the proton capture process.
It is more accurate to say we are nuclear powered.
The first proton accelerator I worked on spent a lot of time doing this.
Also, neutron generators are used in heavy element creation. |
