Report any web site bugs here
NOTE from Darin:
If submitting a bug report, for the best non-turtle service please include:
---------------------------------------------------- Found a new bug: Whenever I update my garage info, the page goes to the 'update successful screen' yet doesn't reload the site. I can get back into the site by opening the URL manually in another window again, but this sure is annoying. Why is it doing this? |
It was doing that because I neglected to change a variable from the "development" forum that needed updating in the "live" forum when I moved the file over. Whoops.
Anyway, fixed. Thanks, Peakster. |
*Sticky'd*
Try it now, Tom.
^^^works just dandy now! :thumbup:
Good stuff. Glad to be of service.
Hey guys, Ive encountered a prob and need advice. After I sign in, if I go to make a post, or as this morning, fill in garage info, after I hit the "submit" button I am told to sign in before I can do whatever it is I,m attempting. Not always but it is apparent to me that something is wrong. It was especially frustrating this am. after I did research for geo specs to put in the garage and wrote up all my list info and now it has all disapeared. HELP. is it my 'puter or is there something wrong with the link or what?is my firewall too agressive? thanx.
Schultz - sounds to me like your login is timing out while you're reading/typing.
I'd recommend you put a checkmark in the "remember me" box next time you log in. |
I didn't know it could/would time out, this isn't my banking site for crying out loud. try that soon . thanx.
After I log in and the computer takes me to the "Forum Home" page, the system is doing/not doing something that I can't figure out....
When I click on a subgroup, the newer messages come up in bold titles. I'll click on to read, then go back to that subgroup listing and the title will be regular sometimes and still in bold other times. Same thing kinda with the Forum Home page listing all subgroups. After I read all new messages in the subgroup, sometimes the "E" symbols are green like still have unread messages and other times are white like should be. I'm on another forum that clears the bold out of the titles so I don't go back to subgroups after I read the messages there. I don't recall clicking on any settings to make that happen, but I have slept since then and my memory sure isn't getting jogged about this...... ????Is there a particular setting that I don't have right, or does everybody's pages do this????? :confused::confused: |
It might be a matter of whether or not you are using the browser back button, which goes to the page stored in your cache instead of reloading.
I usually use this page: http://forum.ecomodder.com/search.php?do=getdaily to make sure I don't miss posts. |
I've been scrolling back up to the top of the thread and using the links beside my log in name to go back to a subgroup or back to home page.
Unfortunately, using browser back button doesn't clear out messages either. I'll start trying the Recent Posts link at top and see if that helps... |
For me it works like this:
Go to main page (i log in at forum.ecomodder.com not ecomodder.com/forum) go to sub group. go to post & read it (any and all new posts). go back to top of page and click on "Ecomodder.com Fuel Economy Forum" http://forum.ecomodder.com/ i'm back at the main page. the sub group says it has unread threads. click on subgroup - no unread threads are there. go back to page and click on "Ecomodder.com Fuel Economy Forum" http://forum.ecomodder.com/ again sub group is now marked as totally read. i'm using firefox 2.0.0.11 |
I see the wonkyness that 02crew describes as well. It's in every vBulletin forum site I've visited.
So I ignore it and basically do what Ben does: use the http://forum.ecomodder.com/search.php?do=getdaily link |
I've noticed today that if I chooose to edit a post inside the thread (php style) that when I click save, it just rotates the indicator next to the button and doesn't actually update the edited post. But if I choose to go advanced and then edit the post it updates with no problems.
Catch my drift? Edit: checking for intermittance |
Is it happening every time?
Something may be up. AndrewJ mentioned something like this last night, and I experienced the "Quick Reply" hang once this morning also. I'm trying it here... let's see what happens now... |
Drat. Worked just fine. (It's much harder to solve intermittent problems...)
I noticed the problem with the quick reply function too, but it seems to be unrelated to my problem.
I'm officially giving up until I can go to the library and try it from another computer. Still the same gig, I can reply to any thread I want, as long as it's not my "5th gen improving aerodynamics" thread. Quick replys just spin the indicator, Hitting submit post or preview post just give me the 404 screen: http://forum.ecomodder.com/newreply....ostreply&t=312 OK, so posting text = no problem. My photobucket links are what's gumming up the works. Time to mess with stuff. Are there new photo-related constraints with the new host? |
crud, it is intermittent for me as well. The only difference was I was trying to add pictures before.
There aren't any new photo constraints. And since Photobucket is off site - it's actually something your browser is dealing with when it renders the page.
Tom - were you adding links to externally hosted pics, or attaching them? |
Tom - were you adding attached images, or links to offsite ones?
Testing quick reply again...
Forum time corrected
On another note: the system time on the server that the forum runs on was incorrect. Someone else had noticed it and mentioned it in a post in another thread.
This was corrected a few minutes ago. If you want to set your local time zone, it's one of the options available in your control panel. |
Stars and PMs
One item since the new server is that the red and blue stars are gone and just the X shows. :o The moderator green stars are fine.
Also, not that it is a big deal, but when someone PMs me...and I check the PM, my vehicles come up underneath thier name (instead of thiers). This has been happening ever since the begining and not just with the new server. Just thought I would throw those out there. |
Nuts on the stars, I'll fix that now, thanks!
Fixed the stars, at least, :)
Double-quotes posting bug
Hi,
I've found that forum posts with double quotes won't work. At least not for me. I'm using Windows 2000 and Firefox. When I replace the dbl quotes with single quotes it posts fine. |
"testing, 1,2,3"
Edit: hmm. Worked for me. That's an odd one. (XP/Firefox here.) When you say it doesn't work, what do you mean exactly? |
"testing" -darin
Works here too |
Settings
Under User CP -> Edit Options -> Miscellaneous (last box) -> Message Editor Interface...
What is everyone's setting? Mine is "Standard Editor -- Extra Formatting Controls". Would that make a difference? (XP/Firefox as well) RH77 |
when i use the search feature i get this.
You don't have permission to access /forum/showthread.php on this server. Apache/1.3.39 Server at ecomodder.com Port 80 Whazzup?S. |
Schultz: could you post more info? Which search feature (there are several on the site), on which page (please post URL), and what search terms?
thanks. |
has a green arrow beside it opens a drop-down you put it there, i think (3)Schultzy's I was actually looking for me. Go figger. (2) http://forum.ecomodder.com/search.php?searchid=50885 http://ecomodder.com/forum/showthrea...t=schultzy%27s I found what i was looking for, but, this happened before so i need to know what I'm doing wrong so i can not do that.so i can do that not? so i not doing that? Troglodyte. You get what i mean? S. |
I don't think you guys have a "www" A record in your DNS zone. http://ecomodder.com works, but http://www.ecomodder.com doesn't. Seems odd, plus IE and Firefox users who like to type "ecomodder" into their browser and hit cntrl+enter won't get here because of the www.
Now www.ecomodder.com is redirecting to ecomodder.com. Must have just been related to the work you were doing.
Im not getting error codes, but my garage is acting up with my fuel log..
it'll show my last updates tank in the bar graph, then its gone, then it comes back then its gone.. first time this has happened.. does someone manually update the garage with the data we input? sometimes its taken as long as 2 days for the log to get upto speed.. donno.. maybe it just has cramps ;) any particular reason for the date format to be funky like that? Im used to Month, day, year 04-12-2008 |
The bar graph image is updated immediately when you update your data. The image filename, however, doesn't change. So if you're not seeing the new data, you're seeing the old, cached image.
If it's strictly in your browser cache, you can reload the page to get the new image. (Different browsers have different "reload" logic - so I'm not sure exactly what you need to do to force images to reload as well as html - you'll have to figure that out.) There's a small chance the image may be cached upstream by your internet provider as well. |
FYI, the same thing applies to the signature images as well.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
