Requestion: KWH
So I know this might be jumping the gun a bit for me, but I know there are others here that have PHEV/EV.
How bout a way to add KWH used to the fuel logs in addition to gasoline without having to convert it over to gasoline KWH yourself? :turtle: |
I agree. This would also be good for people who use engine block heaters and want to record how much power they use per tank.
If there were a KWh field next to the gallons field, I'd use it.
