Restore Engine Restorer
Anybody on here ever use Restore engine restore and see good results? Until here recently I've never really been a high mileage guy besides the $700 civic which I promptly sold when they alternator kept going out. Now that the Prius is up to 165k and is a 2010 consuming 2qts of oil every 10k miles I think it might be interesting to see if it does work.
(https://www.youtube.com/watch?v=VXIu3oo8z4c) (https://www.amazon.com/Restore-00009.../dp/B00HJVEWVG) I'm know I can always just add oil forever but I'm interested to see the effects on the next oil change and would like to keep the pcv and egr cleaner to keep the idle problems away. Planning to keep this Prius until it blows up and it seems like the engine blow by is probably the worst part of the car. Now I wanna preface this by saying I don't believe in any additives besides this one...possibly. Hit me up with your experiences below! |
I’ve used it before and it actually brought compression up some on the engine in question. Not by a massive amount but it helped nonetheless
A quart of oil every 5K miles is nothing to worry about, a lot of new engines burn more than that. I say try it if you want to though, what's the worst that could happen? A lot of people including myself have used it with good results and I have never heard of any problems from using it. I would suggest adding it to relatively clean oil though, so if you are about due for an oil change I would wait until then to add it.
I don't know much about these Prius engines, but bad valve stem seals often cause oil consumption issues and from my experience go bad more than piston rings. The rubber gets hard and cracks with age and no longer seals effectively, allowing oil to get past. The good news is that on a lot of engines replacing the valve stem seals isn't a big deal and can easily be a DIY job depending on the tools you have and your mechanical skills. |
True. Technically if this was an american car this oil consumption amount would be pretty normal. I'll have to take some time out of the day and compression test the Prius.
Great minds have similar YouTube profiles... I posted this same thing a few days ago:
https://ecomodder.com/forum/showthre...tml#post626518 My take would be concerns about gaskets. What effect will it have on the gaskets that the oil come in contact with. Stop Leak seemed to alter the texture and quality of all the gaskets. They're fine, but they're gummier in some cases. Looks weird. |
