Revolt Open Source DC Controller Beta Testing
I started this thread to hold all the testing details and results that's going on down here in AZ. One location should make it easier to find stuff if someone is curious about past details or whatever.
My car basics: 1989 Toyota Corolla 24x 6v US2200 GC flooded batteries Impulse 9 (warp) 3750 lb clutchless Curtis 1231c (originally) http://www.evalbum.com/img/2358/2358b.jpg The car is an elephant in disguise. Most people are amazed at the 7 batteries under the hood and then are really surprised to find 17 more in the trunk. I built it for my longest commute of a 52mi round trip to the west side of town and back. The impulse 9 has a lower torque curve than the warp 9, so i think it behaves more like an 8" motor. Starting in 1st gear gives decent acceleration while 2nd gear is pretty slow to get goin. The Curtis did an adequate job of powering this beast. the whine was annoying and it would often go into current limit mode now that we're into summer. I have a thermal probe in a hole in the heatsink. it's filled with thermal paste near the bottom of the controller - it's pretty good i think, I could see a rise and fall in temp when pulsing the throttle. In the recent hot weather, I saw it get up to 55C in driving around town. Freeway driving is actually less demanding. More info about the car: EValbum: Joseph Yanof's 1989 Toyota Corolla Photos:Picasa Web Albums - Joseph - ecar Album |
I just copied this from the other thread:
it works! It took a while to install, but I accomplished a bunch of stuff. I had to move the heatsink out aways to make room for the mounting flanges and while I had everything apart, I tinned the bus bars. I also put together a simple 4 probe temperature gauge. it uses an atmega16 that i had laying around and 4 thermistors and just scrolls through the temperature readings on an LED display. This shows the rear of the controller with 3 of the 4 probes in the controller. I had one taped to a capacitor, another wedged in between the space above a mosfet, and another wedged in between the space above a diode. I used folded up paper to wedge it in there so that the thermistor was pressed against the top of the mosfet/diode case. http://lh3.ggpht.com/_ZoZeCCvxzC0/Sm...6/DSCF2423.JPG Installed in the car amongst the web of wires... http://lh3.ggpht.com/_ZoZeCCvxzC0/Sm...6/DSCF2431.JPG The temp probe circuit and display just sits in the front seat for now... http://lh4.ggpht.com/_ZoZeCCvxzC0/Sm...6/DSCF2433.JPG The coolest thing for me has to be the silence when moving slow... I'm too used to the curtis and its squeal! Paul, I noticed the 'bucking bronco' phenomenon that I think you mentioned before. I'd guess that the control loop is acting too fast and gets into an oscillation - it sounds like you have it worked out, so i'm anxious to try out the new loops. The accelerator position = torque thing is quite different. I'm used to having to press the pedal ever so slightly and then press further and further to go faster and faster. Now, it's almost the opposite! I have to press the pedal deeply and then release it as the car accelerates. I only took a few trips around the neighborhood (got a little late), but i did get a little bit of temperature data. Ambient temp = 34C. I did 8-10 accelerations to 25 mph pulling 200-400 amps each and I noticed the mosfet and diode temp get up to about 60C while the cap temp seemed to stay lower in the low 40's (don't remember). I want to double check the accuracy of my probes, but I think they're pretty good. More testing to come! |
Hey Joe! Do you have the 6 ISP wires accessible even with the enclosure on? I think my 6.7" diameter motor behaves pretty different from your 9" motor. It seems to me that something that feels smooth to me feels pretty jerky to you. I think your motor is lower inductance.
I think it's going to take several variations on the throttle to get it to what feels good to you. It would be nice if the ISP wires were already out with the other wires, so you could just hook up your laptop (and stk500) and program the chip without taking off the case each time. I'm not sure if a tuned loop for me will behave the same for you. I'll send you code for the PI version with a conservative throttle ramp. I may be using too large of P and I values for your motor, though, but we can try it and see what happens. If it is still jerky or oscillating, I'll know to make the P and I smaller. I'll also send you just a basic ramping code program, that takes both pwmDuty AND current into account, so it might feel more similar to the Curtis. Also, I'll make sure the overtemp is set to about 75 degC to start. One reason it might feel like you have to push a lot on the gas to get going is that I have a pretty conservative dead zone for the throttle. Maybe it's too big? I just didn't want to risk having the car take off because the pedal was SLIGHTLY above 0 throttle. |
I don't have the wires easily accessible at the moment, but that should be easy to arrange. It's not always jerky, just sometimes at the right pedal input. going up the driveway was particularly jerky.
With regards to the deep pressing pedal, I think it's just because my setup requires a lot of amps to get going (combination of lotsa weight and goin with the impulse 9 motor). For example, when I started off in 2nd gear with the curtis, I'd peg the output at 500A for 5 seconds or so before the car got going enough that the current dropped. While that was just a small pedal depression before, that'd require flooring it now. It's just different... How does this other throttle thing work? |
The one you have right now is a current ramping code I believe. Increment current . It's not a PI loop. It sounds like at low RPM, the current was swinging back and forth. A properly tuned PI loop should be much better, but it might take a few tries to find the right P and I for your motor. I'm certain it would be different from mine. Probably smaller P and I values, but I don't know how much smaller.
The third option looks a little like this: if (pwmDuty > throttlePos) { pwmDuty--; } else if (current > throttlePos) { pwmDuty--; } else if (pwmDuty < throttlePos) { pwmDuty++; } So, you don't get the jerky starts from throttle only being proportional to pwmDuty, since current can't be bigger than throttle either. |
Interesting! I'd definitely like to try some sort of PI loop - just curious, why no derivative term?
I like the third option too - It sounds like a way to have control of current at low speeds; i'd probably set it up for half the pedal range or something. Maybe this middle term would be: else if (current/2 > throttlePos) { pwmDuty--; } with 144V input and the Curtis, I'd rarely press the pedal more than 65% or so, meaning that my max required duty cycle is about .65. I'd cruise around 50%, and hill climb at 65%. (i'm basing these numbers off of the ratio of battery amps to motor amps). Occasionally, I'd punch it to merge or something, but that is rare. I really like the idea of the PI loop to control current though - seems like it would truly make the hardware overcurrent feature more of a a protection feature than an integral part of the controller operation. I'm toying in my mind how to integrate the two... haven't figured it out yet. |
I just took a drive with a PI loop that is pretty well tuned to my motor. However, with the added feature that throttle doesn't change instantly, but rather has a max ramp rate. So, let's say you floor it. The slowThrottle will be heading toward actualThrottle, and the PI loop will be making sure the current is exactly matching the slowThrottle on it's journey. It felt really good in my car, but that doesn't mean anything. hehe. If you feel oscillations or jerkiness, I'll decrease my P value some and we can try it again.
I didn't include a derivative term because the EVTech people suggested to me that it is more likely to cause instability in this context. I read up on it, and each control loop I read about for high power motor controllers didn't include the derivative part. Based on the graphs I've gotten from my serial port, it seems that the current converges to the throttle exponentially, so I think it's OK with just P and I. I was thinking about how to integrate the 2 also! Lots of fun stuff to try! I'll email you the PI version with P = 18 and I = 150 (meaning 18/32, 150/32000). If it's too jerky, I'll send you one with P = 10 or something like that. Or you can just change Kp in the program to whatever you want! hahaha! It's just a variable. I keep forgetting you have an STK500. As an example, changing Kp to 10 in the program would be the same as changing it's actual value to 10/32. |
sweet! I'll give that a try.
I tried to come up with something that integrates the throttle to PWM and a PI loop and couldn't do it. Only thing I could come up with was using a PI loop in the 2nd term if current>pwmDuty. Here's another idea - maybe kinda hairbrained. what if the the throttle didn't control PWMduty or current, but controlled output power. PWMduty is proportional to output voltage, we're measuring current, so the product of those two would be power (or something proportional to power). I have no idea if this would work, i haven't thought through the details. well, i'm sure we can get it to work, but i don't know how it'd result in 'feel'. think about it... |
I just got it working with throttle proportional to power! Very nice feel! It's different from both of the others (to current or to pwmDuty). It really feels like a hybrid of the 2. My ramping is a bit too slow, but I'll take care of that. It feels really nice! That was a really really good idea you had! I'll email it to you later. My son just woke up. Great idea, Joe!
EDIT: Actually, I can also try a PI loop on this so as to make power converge to throttlePos exponentially. |
I loaded the new code that had the pi loop and it worked a lot better. The ramp rate might be a little slow, but I'm more interested in the new 'power' code. Paul, you'll have to send that when you get a chance.
I think my temp probe thing is about ten degrees too high. That's at ambient temp though, not sure about higher temps. I think one easy test would be to put it in boiling water too see what I get. Nevertheless, I cruised around the block tonight and watched the guage. Temps on themosfet and diode got to around 100C at some points, but that's what my guage read, so I'm not sure that it's really that high. I think the guage I have inthe heatsink is pretty accurate (I bought it online) and it reads the temp at the base of the controller. This reading changed quite a bit with throttle, but seemed to hover in the high 40s. On, it was actually kinda cool out tonight, 32 C. If these numbers are right, we may need to look into better cooling or reducing heat. I read on the zeva site about ians design and how he's down to 5 ohm gate resistors. Paul, I think you mentioned some options to reduce heat... |
hm, was just thinking that brief excursions to high temperatures might be ok. i guess as long as the components stays below some maximum temp and nominally stay rather cool (like below 80C?) they oughta last pretty long. I noticed that after accelerating the temps would be high, but they'd drop in minute or so...
i need to verify my measurement system and do some more testing... |
man, keep forgetting things. also, i noticed that the minimum amps I can send to the motor is 80 amps. any idea why this is? do you notice this too?
On my charger, i noticed that the optoisolator has some lag when the voltage is rising, almost like it has some internal capacitance. Thus, there was a minimum duty cycle that would actually get through to the gate driver. do you have this problem too? or maybe it's something in software with the minimum throttlepos maybe? |
There are several things for future versions, like multiple gate drivers to allow for smaller gate resistors. Another thing that would help is if I would have torqued the stupid mosfets'/diodes' clamps all the way down. I'm such an idiot!!! If you ever want to do that, you will have to unsolder each gate resistor from the control board, unsolder the 2 thicker power ground wires from teh control board, and then remove the control board, unbolt the 5 bolts, flip it over, take off the base plate, tighten the clamps, and then re-assemble. I'm sorry about that. Maybe they are OK though.
Syncronous rectification is another option. Another option is to have 2 separate heat spreaders. One for the diodes and one for the mosfets. Clamp teh mosfets' back DIRECTLY to the heat spreader, which makes the heat spreader wired to M-. The heat spreader then would have to be isolated from the base plate. Similarly do the same with the diodes. Must go to bed! haha! That's really serious about the 80 amp minimum. Maybe I messed up so that the dead zone does nothing, but then the throttle goes from 0% to around 12-13%? I really need to look at the code to see if that is true. I don't have a motor amps measuring thing. I can sort of measure battery amps, though, and I have never noticed that. hmm! I'll check tomorrow. |
I ran the numbers for smaller gate resistors for various design points: The first is the original 30 ohm, the 2nd is 15 ohm, and the last is 5 ohm. On paper at least, it shows up to ~50% less heat with the 5 Ohm. http://lh3.ggpht.com/_ZoZeCCvxzC0/Sm...controller.jpg Quote:
I'm skeptical of synchronous rectification. I think it makes sense if the diode is on for a large portion of the duty cycle, but in our case, we're often above a duty cycle of 0.5. From the chart, the Wdiode is often less than the sum of the Wfet (due to Rds) and Wswitching (indicating that adding another set of mosfets would actually increase losses). Even for the 5 ohm case, there's only a significant advantage at low speeds. I think sync rectification is most useful for low voltage power supplies that convert 120V down to 12 or something. In that case, the duty cycle is so low that the mosfet is only briefly on and the diode is on a long time, and thus, is the source of a lot of heat. I do like the idea of eliminating the thermal pad... seems like it creates other problems, huh... Quote:
I felt that the minimum throttle is very noticable. like, cruising at 25mph, i'd back slowly off the throttle, i could feel the torque dropping, and then bam - instantly zero. For me, it's at 80amps, but maybe it's less at 72v and a 6.7" motor. |
Ran into a new problem that I think is purely software.
First, some background. I have my battery volt meter across the controller battery inputs, B+ and B-. Thus, I'm essentially reading the voltage at the controller. This is nice because I can watch the voltage on the caps rise as they precharge, but that's really about it. Also, I have my contactor wired to the throttle pot switch. I set it up so that the contactor is open when my foot's off the pedal, but closes once it's depressed. It seems that most people have the contactor close for the trip duration, but I like the reassurance that the battery gets disconnected when I step off the pedal. If something goes wrong, my first instinct - to get off the gas - will be a first line of defense in breaking the circuit. The precharge resistor keeps the caps charged when I'm off the throttle. SO - the issue. I noticed my voltage drop to zero and then rise slowly again like the caps were precharging. This happens when I take my foot off of the throttle too fast. What's happening, I'm pretty sure, is due to the throttle ramp rate. I take my foot of the pedal, the contactor opens, but the PWM signal hasn't yet gone to zero. So, the controller is still sending power to the motor, but the battery is no longer connected, and the caps get drained to zero. I'm pretty sure increasing the ramp rate (at least the ramp down rate) will solve this, so it's an easy fix, but a problem I definitely didn't foresee! I posted this in the other forum... Testing temperature update! My probe thing is whacked! I brought out the rice cooker filled with water and put in a temp probe from my handy clamp meter and the 4th unused probe from my hacked together POS, turned it on and recorded the two values as the water temp rose. at an actual temp of 58C, my probe read 102C at an actual temp of 75C, my probe read 152C I knew it was a little off at lower temperatures, but it's way off at higher temps! So, firstly, if the top of the mosfet cases are only ~60C, and maybe it's a bit warmer at the junction, that might be ok. It was only a 4 mile trip around the block, so we'll have to see what happens on longer runs or harder accelerations. secondly, i'd like to fix my frickin code! I didn't necessarily plan my circuit too well and ended up with quite a ridiculous ADC to Temp curve that's 3rd order. Straight from excel, I was using this: tempfine=0.00000041*(ADC^3) - 0.00055497*(ADC^2) + 0.35803595*ADC - 6.14221231; where tempfine was initialized as float. I'll admit that I really don't know how this works for microcontrollers - I initially coded it up and loaded it, saw a value that was roughly room temperature, then squeezed a probe in my hand and saw another number that was roughly body temp and concluded it was good! Obviously it isn't! Any ideas? |
good diagnosis. That's exactly what's happening, Joe. If you are using the PI version with the slow ramp rate, to increase the ramp rate, there's a constant called THROTTLE_RAMP_RATE (I think it's called that). I think right now it's set to 4 maybe. Try changing it to 8 or 10 or something and see if that helps.
How is the testing going and how many miles do you now have on the controller?
I think anything that would have failed in an infant mortality kind of way should have failed by now. Now it's just longevity - will it last 1000 miles or 100,000? We just gotta run it and find out. I also have this post on the other page: Paul suggested we investigate the sources of heat generation in the controller by changing the switching frequency in half. The result should reduce the switching losses by half at the expense of an audible whine and higher ripple current (I think?). It'll be easy to implement as well - just change the micro frequency to 8mhz using the internal oscillator. The effect on temperatures, however, should be less than half - that is, the temps should be slightly more than half of what they were before due to the other sources of heat (diodes, Rds_on) that aren't changing. Anyway, this would give us an idea about what to expect from reducing the gate resistance to speed up switch-on/off times, if we decide to pursue that. Some observations: 1 - The ~8khz whine is not very loud, but it is very high pitch and I found it quite annoying. I don't think I could take it if I had to leave it like that. 2 - I increased Kp in the PI loop to account for the slower processor, but I forgot about the ramp rate. It took what seemed like forever to ramp up in current. 3 - I froze the micro once. Stepped on the pedal too hard - not sure why it locked up, but it did. It was very reliable at 16Mhz, so not sure why it would change - maybe something to do with the overcurrent reset or the response of the PI loop at the slower processing speed? I plan to change it back to 16 Mhz, so I'm not going to worry. 4 - As expected, the 'feel' of the controller didn't change (aside from the slow ramp). 5 - Temperatures. Conveniently, the ambient temp was about the same as in the video a few pages back - 42C. The only difference was that the sun was going down tonight while the video was in the sun, but since nothing is exposed, I think only the ambient temperature matters. I went on the highway pulling the same amps until the temps stabilized. Mosfet and diode were around 61, capacitor was at 65 (had just clicked up to 65 when I got to my exit - might've gone higher?). The heatsink probe was reading 52. If you happened to watch the part of the previous video where the camera is right in from of the probe display, you might remember the mosfet reading 67, diode 63, the capacitor a little lower than that (at that point), and the heatsink probe at 56C. *Remember, these are just probes that are touching the case of the mosfets/diodes to get a ballpark temp reading. So, Before at 15khz: Mosfet - 67 Diode - 63 Cap - 60ish Heatsink - 56 Now: Mosfet - 61 Diode - 61 Cap - 65 Heatsink - 51 6 - The switching components ran cooler, but the caps did not. Previously, I had never seen the caps rise higher than the mosfets/diodes. Now, I suspect with the lower frequency and higher ripple current, the caps are generating more heat and are rising in temp. 7 - Previously, the mosfet ran hotter than the diode, but at half frequency, they were roughly the same temperature. Physically, they are fairly well thermally coupled due to the copper heat spreader, so I'd think a close temp is to be expected. The difference in temps before is likely due to the extra switching heat that is now cut in half. When the mosfets were generating a lot of heat before (more than the diode), they ran hotter. 8 - It's always interesting to compare the mathematical models to real measurements. Using the models for a mosfet and diode presented quite a few pages ago, the heat generation at 15 khz, half duty cycle, and 200 motor amps is 449W. Cutting the frequency in half reduces this to 273W, or a 39% decrease. If we assume that the thermal resistance stays the same, we can then say the component temperature-above-ambient should decrease by 39% as well. This hypothetically would give: Mosfet - 57 Heatsink - 51 diode - should stay the same? It's producing the same heat as before, so... However, this is not what was measured - the predictions are too low. The actual temperature changes are closer to a 26% decrease in temp, significantly less than the 40% prediction. Of course, there are so many assumptions that go into the model (which itself is just an approximation), so maybe these results are actually pretty good. So, here are some other model heat gen results to chew on: 15 Ohm Rgate - 37% less heat generation 10 Ohm Rgate - 50% less heat generation 5 Ohm Rgate - 64% less heat generation |
