EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Reynolds number calculation (https://ecomodder.com/forum/showthread.php/reynolds-number-calculation-14818.html)
aerohead 10-09-2010 02:12 PM
Reynolds number has to do with a bodies size in relation to its velocity,moving through a viscous fluid and boundary layer conditions,whether the boundary layer is laminar or turbulent is dependent upon it.
The number is named after Osborne Reynolds who introduced it in 1882.
For road vehicle work the Reynolds number is defined by:
Length X Velocity / Kinematic viscosity
L X V / v
Kinematic viscosity is the 'coefficient of viscosity',also 'absolute viscosity',also 'dynamic viscosity',and also just 'viscosity', divided by density,or
viscosity / density ( Mu over Rho )
EXAMPLE: Toyota Prius,approx. 14-foot length,at 60-mph ( 88 feet per second ),on a 50-degree F day,( v = 0.00015 ft-squared/second )
Then,--------------- 14 X 88/ 0.00015 = 8,213,333 = Reynolds number
Kinematic viscosity can be found in tables.You can directly measure your vehicles length,and you just pick a velocity in feet per second.
P.S. v at standard temp and pressure is 0.000158.
Knowing the Reynolds number allows calculation of surface-friction drag,or the 'skin-friction' component of your vehicles profile drag.Subtracting the skin friction component from the profile drag reveals the 'pressure drag' of your vehicle which is governed by flow separation.A perfectly streamlined vehicle will have zero pressure drag and only a bit of skin friction which is unavoidable to the viscous qualities of the air.
3-Wheeler 10-09-2010 08:37 PM
Originally Posted by aerohead (Post 198164)
.... Kinematic viscosity is the 'coefficient of viscosity',also 'absolute viscosity',also 'dynamic viscosity',and also just 'viscosity'....
If you're working with these equations, it will make a difference on whether you use absolute or kinematic viscosity.
The units for absolute viscosity are quite a bit different than kinematic viscosity.
Jim.
Patrick 10-10-2010 09:09 AM
20,000,000 seems awfully high. From memory (it's been a long time . . .) the rule of thumb for Reynolds number at STP was 10,000 X MPH X length in feet, which would yield 10K X 60 X 14 = 8,400,000. This seems more reasonable to me.
aerohead 10-13-2010 05:11 PM
difference
Jim.
Jim,yes it absolutely critical that kinematic viscosity be used.
aerohead 10-13-2010 05:25 PM
6380?
Patrick,sometimes kinematic viscosity is given as it's reciprocal,which for standard air is 6380.
In my table of SI units kinematic viscosities listed have been multiplied by 10,000.
The formula I have for Reynolds number is also from Daugherty.Hucho uses the same equation.
aerohead 10-14-2010 05:02 PM
goof and correction
In the Prius example I transposed the Reynolds number of a 35-foot moving van into the solution for the Prius.
Patrick caught the numerical mistake and the whole thing didn't register with me until last night.
I went back and edited the original thread where you will find a significantly lower value.
My 'math' is good enough now that I think I may be ready for Arthur Anderson,ENRON,or Moody's Investment Services.
I'll see if I can clean up the skin-friction thread.
jvr 02-16-2011 05:42 AM
reynold number calc
hi,
i want to calculate the Reynolds number of exhaust gas with a given temperature(°c) and massflow(g/s).
What is the fastest way?
thanks in advance
RobertSmalls 02-16-2011 07:26 AM
That's flow through a tube, which is a different calculation than the above equations for flow across a plate. Use this:
Re=D*V*rho/mu,
where D=dia, V=velocity, rho=density of exhaust gas, mu=viscosity.
The assumption that exhaust gas = air (rho=1.3kg/m^3 at STP) should get you within an order of magnitude.
some_other_dave 02-16-2011 06:44 PM
One of the fun parts with that equation is that exhaust gas is HOT. And it cools relatively rapidly as it moves through the exhaust system. So its density changes by a decent amount...
-soD
alambe 02-18-2011 02:57 PM
While we're doing the math, what is the effect of temperature on skin friction and pressure drag. I'm thinking warm day vs cool day vs cold snap like we recently had.
(I should do it myself, but it's been so long I don't even know where to look for the numbers)
aerohead 02-18-2011 05:43 PM
where to look
In 35-years I've seen but a single table for air density as a function of local temp and baro. pressure,which is what you need to know.
If you have a local dynamometer shop you might pester them in to showing you how to do the conversion.
Once you know your density (rho) you can plug that into your formulas.
RobertSmalls 02-19-2011 08:59 AM
Density Altitude Calculator - English/Metric, Relative Humidity
PV=nRT tells you that for an ideal gas (which air is, to a good approximation), density is linear with barometric pressure.
jime57 02-19-2011 12:46 PM
-soD
Which leads to a considerable amount of head scratching by designers of high performance exhaust manifolds(headers). It gets so complex that most designers just give up on calculations and develop the diameters and lengths experimentally on an engine dynamometer. Throw in stepped diameters and the problem becomes totally intractable. ;)
gone-ot 02-19-2011 01:55 PM
...and, because of the exhaust large temperature change, most people simply use an approximated "average" value.
aerohead 02-21-2011 05:41 PM
linear
Isn't the linear relationship valid if only barometric pressure is the single variable?
RobertSmalls 02-21-2011 06:42 PM
Yes. Here's the relationship with two variables:
PV=nRT
nR/V=P/T
where nR/V can be equated with density, and T is absolute temperature, in Rankine or Kelvins.
If you want to add a third variable like humidity, or if the ideal gas approximation isn't good enough, it's time for a lookup table. I don't know what method the Javascript calculator I linked to uses.
