Old 07-30-2008, 11:37 PM   #31 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
Just like to say welcome! I love seeing more and more SUV owners joining this group. Looks like there's plenty of room for improvement with the GMC Jimmy. If you do a decent amount of highway aero improvements would be a good place to start otherwise ditch as much weight as possible and work on the aero later.
A few quick/low cost aero mods
Roof racks a great start - Sounds like you took care of that already
Grill block - Partial block is easy/cheap.
Block tow hook holes - Noticed most jimmy's have them.
If you've got mud flaps - Ditch'em
fill in any gaps around lights/Panels - Weather striping I hear works great for this
More advanced/expensive aero mods
Wheel covers
Rear wheel skirts
extend the air dam down
Skid plate - Picked up up about 2mpg highway on mine
cover as much under body as possible - With 4x4's it's hard to do one smooth panel
Weight reduction
Ditch spare tire/Jack - Got AAA?
Any extra tools, oil, etc
Seats - If you're the only one in the car most of the time.
More expensive weight reduction
Lighter rims
Lighter Brake rotors
Lighter Flywheel
If you'd like to see what I've done on my Cherokee so far check out my post here.
Feel free to add to the list guys.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 07-31-2008, 11:28 AM   #32 (permalink)
Icarus - '11 Ford Mustang GT
90 day: 20.71 mpg (US)
Walter - '02 Chevrolet Suburban LT
LRR tires - BFG makes some all-terrains that made the official list, max inflation on the tires,
electric fan,
cut out the weight (seriously - like hulling your hood),
shave any trim (especially a roof rack),
get a high-flow intake,
replace the muffler with a straight-through model,
Get all the fluids changed with the best you can afford,
Most importantly - get a good tuneup - if it was free, it probably needs some TLC - plugs, wires, PCV valve, etc.
Old 07-31-2008, 11:33 AM   #33 (permalink)
Also, specifically for your truck, you can get underdrive pulleys from Summit Racing. My parents had a Jimmy just like yours, and it always ran great. Keep in mind that the 4.3 V6 is a Chevy 350 V8 with two cylinders shaved out of it. A lot of parts will interchange. Edelbrock at makes (made?) an aftermarket aluminum intake for the 4.3, and exhaust headers are available for that model, too.
Racing seats are a great way to shave pounds, too.
Old 07-31-2008, 11:58 AM   #34 (permalink)
Daily Driver - '01 Ford Explorer Sport
90 day: 18.12 mpg (US)
Send a message via Yahoo to Tony Raine
yeah, at least the jimmy is a small suv. i think a free one is great. i'm not much of a chevy guy, but the 4.3 is a great motor. it sounds like you are off to a good start. i think the best thing with an SUV is just keeping it in good running condition. get some stock replacement spark plugs/wires. if i keep my explorer much longer i think i'll invest in an electric fan.
My Intro
Old 07-31-2008, 11:43 PM   #35 (permalink)
Rolling Junkyard - '98 GMC JIMMY 4D 4WD SLT
90 day: 20 mpg (US)
The Sable - '01 Ford Sable
90 day: 30.74 mpg (US)
The Jeep - '01 Jeep Grand Cherokee laredo v6
90 day: 20 mpg (US)
For a small update i mocked up a temprory grill block with newspaper backing and tin foil cover. I covered the whole grill because above the license plate is a hole which air can come in anyway. It might last a week or so which is fine by me because i made it out of scrap. I just hope my car doesn't go into meltdown. The next thing i am going to do is remove the tow hooks and cover those holes as well.
A question that has been plaguing me is where to by abs plastic to build wheel skirts and such. Any recommendations would be greatly appreciated
Old 07-31-2008, 11:51 PM   #36 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
Did you flush and refill your cooling system yet?
Old 08-01-2008, 12:08 AM   #37 (permalink)
90 day: 20 mpg (US)
90 day: 20 mpg (US)
I'm not even sure how to do that. I guess ill have to read about it? do you mean just draining all the coolant and then refilling it?
Old 08-01-2008, 12:34 AM   #38 (permalink)
Yes but, run something like prestone cooling system flush through it at least once. The bottle will have directions on it. I know that GM vehicles love a good clean cooling system. One thing to watch out for is if dexcool has eaten the intake gaskets, filler neck and water pump seals. I have had to replace them on our suburban, a friends and soon I will be doing a friends 2000 blazer with the same cooling issue.
Do you plan on getting a scangauge? This will teach you how to drive your truck for max mpg.
Old 08-06-2008, 01:15 AM   #39 (permalink)
90 day: 20 mpg (US)
90 day: 20 mpg (US)
Old 08-06-2008, 01:34 AM   #40 (permalink)
Red Egg - '95 Ford Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Dodge Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
I would write "for sale" on it in the liquid chalk with 'trades welcome' and see if anyone bites.
List of Low Rolling Resistance Tires Daox EcoModding Central 57 05-13-2019 02:17 AM
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 05:24 PM
Calculating Rolling Resistance SVOboy EcoModding Central 2 02-15-2012 09:43 PM
Rolling Wind Tunnel CFD trebuchet03 The Lounge 25 04-25-2008 10:06 PM
