Old 06-27-2010, 12:15 AM   #1 (permalink)
weird results: octane matters?
Just got back from a trip to yellowstone park with my 2006 mazda 5 5 speed:
MazdaUSA - Wireless Home
Despite the epa 27 mpg hwy rating, I have always gotten around 30-32 hwy mpg at speeds up to 65 mph. The owners manual specs 87 octane.
This trip going west across south dakota, wound up bucking a 20 mph headwind all the way across the state while traveling 75 mph with the air on and got only 25 mpg. ( worst hwy milage ever for the car)
In the park, I saw that the 87 octane had 10% ethenol and wound up putting in 91 octane premium instead. This was after getting 34 mpg in the park with the 87 octane. ( this car gets really good milage in the mountains for some reason)
This 91 octane tank got slightly over 39 mpg, ( based on when the gas gauge started moving from being topped up. ( about 3.8 gals used, normally sees 115 miles or 30 mpg, but this tank got 148 miles for 39 mpg.)
Intrigued, I used premium for the rest of the trip, ( out to craters of moon nat'l monument in idaho and then back home, ( milwaukee) and got the best hwy milage the cars ever seen, at 35 mpg at 68 mph with the air on. This is better than the previous best of 34 attained by traveling at 60mph with no air and calm conditions across rural indiana.
Even coming back across SD with a smaller headwind and 79 mph I saw 27.54 mpg.
The only logic I can come up with is that at these high load conditions with 87 octane the engine must be pulling back timing a small bit to keep from knocking, ( killing some power and needing more throttle), and doesnt have to with the premium gas. Ultimately, I saw a small fuel cost savings as fuel economy went up a few % points more than the extra fuel costs did so cost per mile was slightly lower using premium.
The big question is that if this car does run better, ( at least at higher speeds) on premium fuel, why does mazda spec 87 octane?
Thoughts anyone?
Old 06-27-2010, 12:37 AM   #2 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
i dont know but i see more ing timing with 93 than i do with 87, ans see a few mpg difference and some power diff, that is in my 09 taco and 07 se cam.maybe the vvt-i or mazda equivalent makes up for it. and uses it to is advantage.
Old 06-27-2010, 01:53 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Generally they'll spec whatever octane the car needs to live. It could be they have it set up to advance timing for slower-burning fuels and this might actually be to your advantage, but they just didn't want to scare away owners by requiring it.
Or it could be random tank to tank variation
Old 07-08-2010, 06:37 PM   #4 (permalink)
Oh Deer - '03 Ford Ranger XL
90 day: 33.97 mpg (US)
I had used 93 octane Shell V-Power in my tank when I was driving farther on the highway each trip. As gas got more expensive I switched to 87 octane trying to save a few $$$. My mileage went down 2-3 mpg with the 87 octane. Now I just pay the extra and run the 93. My mileage is back up and the engine seems to run smoother. I'm not a mechanic so I can't explain it but that's what happened. The best mileage I have gotten was when I could find 87 or 89 octane without the ethanol. The "straight gas" delivered great mileage. I can't find it around here any more.
Old 07-10-2010, 04:36 PM   #5 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
i always run premium cause with both of my cars i picked up 1-2 MPG from premium gas
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 07-11-2010, 02:11 AM   #6 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
Do you get better gas mileage with premium fuel?
It's a definite maybe.
Old 10-29-2018, 12:00 PM   #7 (permalink)
Full sized hybrid.
Isaac Zackary's Avatar
Suzy - '13 Toyota Avalon Hybrid XLE
90 day: 37.18 mpg (US)
I've been using 87 octane for the past 7,500 miles in my Avalon Hybrid and been getting a steady 41-42 mpg. But I decided to use regular fuel, 85 octane (81, 83 and 85 are marketed as regular in Colorado in different parts) instead of paying 30 cents more for 87 octane. Interestingly on my first tank I got 48.0mpg. I don't know if this is just a fluke or if I actually got better fuel mileage just yet. I guess I'll find out next week at my next fueling.
EDIT:
Never mind. I just redid the numbers and got 41.1 mpg.
Old 10-29-2018, 07:27 PM   #8 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
ZOMBIE THREAD ATTACK!!
Now I'm curious, did you do this just for Halloween?
Old 10-29-2018, 08:56 PM   #9 (permalink)
Full sized hybrid.
No. I think I just have a bad habit of looking for a thread about something similar that happened to me and then posting to it without even checking the dates. I was on a forum once where if you made a new thread about something remotely close to another previous thread the moderators would very often lock the new thread and direct everyone to continue with the conversation on the old thread. So I guess that's where I got it from.
Still, I'm all confused about this octane stuff. I mean, I know how it works and all. But the car calls for 87. But I drive between 5,000 and 12,000ft. So that would seem to merit a lower octane. But how much lower? If I buy 81 will I be doing harm to the engine? According to what I could find here: https://www.sae.org/publications/tec...ontent/872160/ It says that you shouldn't use less than 0.2 additional octane numbers per 1,000ft. That would mean I would need 86 octane for 5,000ft. But then again the article is from 1987! Could things have changed since then?
Old 10-29-2018, 10:38 PM   #10 (permalink)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Well, your Avalon has an OBDII port. It's a simple matter to connect a gauge and see what the timing advance is doing.
My Acura runs 40 degrees advance when running on about 90 or above octane, but on 87 does a bit less advance during freeway cruise. When I'm regularly driving the car, I can tell what octane is in it just by feel. It has more power when I load the engine heavy at low RPM.
I got the same MPG though regardless of octane.
Isaac Zackary (10-30-2018)
87 octane vs 89 octane kill-9 General Efficiency Discussion 51 02-14-2013 01:12 PM
Need some victums to help me confirm results Nerys EcoModding Central 17 05-12-2011 03:29 PM
Effect of fuel octane number on FE hummingbird EcoModding Central 32 10-28-2009 12:50 AM
87 octane and retarded timing Quattro General Efficiency Discussion 4 02-20-2009 08:29 PM
