Old 06-25-2010, 09:06 AM   #1 (permalink)
Novice but learning!
Spill plate question
Hello all,
another question regarding spill plate design.
Please see photo below, why are the front wing spill plates this shape???
Old 06-25-2010, 09:43 AM   #2 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
To add downforce in front. The plates on the sides are probably to aid in straight line stability.
Old 06-25-2010, 09:56 AM   #3 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
I'm pretty sure he means why they have that curved shape cut from them. Styling, maybe?
In Reason we Trust
Old 06-25-2010, 10:00 AM   #4 (permalink)
ChopsQube's Avatar
Oh... Didn't see that.
Maybe integrated VG's!
Old 06-25-2010, 10:05 AM   #5 (permalink)
Thanks, lol yeah why that shape? Few cars have them in USA, wondered why?
Old 06-25-2010, 10:58 AM   #6 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
the long vertical edge below the chord reduces the spill round from the high pressure top surface, they are so long it make me wonder if he's trying to cut ambient pull-in, nee ground effecting the front chord.
As for the plate above the chord, I guessing it for flow reduction. at 315+ the frontal area and normal spill plate sides mixed with Hi speed laminar flow above the chord would box in the air effectively creating a parachute effect. At those higher speed the lower surface can generate a lot through a diffuser effect so you don't need the air on the top, so I'm guessing they're bleeding it out at the sides.
just my idea
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 06-26-2010, 02:35 PM   #7 (permalink)
spill plates
I will add one more consideration to what's been posted.
If the car and driver were placed on a turntable,with the C.G. directly over the pivot point and a large and powerful air blast were directed from either side of the car,the aerodynamic loads acting on either side of the pivot would be 'balanced' by the spill plates.S.W.A.G.!
The palm trees got me thinking about what would happen during a run if a crosswind gust were to 'pop' the car.
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 04:01 PM
Wisconsin Conservation Driver license plates bennelson EcoModding Central 9 09-04-2008 09:36 AM
Front plate alternatives pasadena_commut Aerodynamics 8 07-12-2008 10:30 PM
Front License Plate Mounting Harry6 Aerodynamics 6 04-01-2008 08:56 PM
