Old 10-12-2010, 01:00 PM   #1 (permalink)
92 VX CA to Fed conversion gone wrong!
Hello friendly modders,
I have been putting this off for 3 months now, but now I realize I need your help! The mechanics here in CA are dumbfounded and don't understand VTEC-E!
My 92 CA civic VX has been a fun project over the last few years, but I have not been able to get lean burn to work! Here is some history that may help out:
I bought the Civic with 150,000 miles. Shortly after the head blew and the transmission was grinding so I bought a Japanese replacement engine from Nippon Motors in LA. The engine was stamped D15B and the trans was a junkyard vx/cx replacement. I kept the same CA intake manifold and bought a new o2 sensor and p07-A00 (fed) ecm.
After I plugged in the FED ecm the car would stutter horribly and slow with no power to the wheels when the throttle pushed down less than halfway. This happens in 2 - 5th gear, but not in first. I have to give it way more gas to make it jump back to regular driving, and as soon as I shift up, it does the same thing unless I give it way more gas. It is impossible to drive this way. I thought that the ecm might be bad, so I bought another one and it is the same story.
The info from one of the tutorials said that with a 92 CA VX the only thing needed for the conversion is a FED ecm:
http://ecomodder.com/forum/showthrea...n-vx-7295.html
I now have the stock CA ecm in there just so I can drive it. Is there something I'm missing? I average about 32-44 mpg with the CA ECM. Please help!
Old 10-12-2010, 02:53 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
To make the conversion you should need a 5-wire wideband o2 sensor made by NGK as well as the wiring from that to the fed. p07. Perhaps this is what you're missing.
Old 11-06-2010, 05:52 PM   #3 (permalink)
I have the P07 and the 5 wire o2! I lose power when the p07 is hooked up. Im going to replace my IACV, due to a crazy idle bounce and check the vtec solenoid. My engine has VTEC-E stamped on the valve cover. I'll re-post as soon as I figure anything out!
Old 11-06-2010, 05:59 PM   #4 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
Does it function properly with the CA computer?
Old 11-08-2010, 02:20 PM   #5 (permalink)
Yes it functions properly with the CA ecu. I have the 92 with the 5 wire o2, so it should simply work with a fed ecu swap. I got my info from:
Old 11-08-2010, 08:44 PM   #6 (permalink)
If you transfer all the wiring and the computer, then the only thing that could be holding you up is a sensor issue?
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
CA->Fed VX conversion won't pass smog :( mango EcoModding Central 7 07-22-2010 01:53 AM
'89 DX or '92 VX? War_Wagon EcoModding Central 1 03-03-2010 09:43 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
cx conversion to vx model chris_marsho Off-Topic Tech 0 07-26-2008 11:57 AM
