Old 10-19-2008, 11:19 PM   #1 (permalink)
DMC - '99 Honda Civic DX
What causes me to have such good mileage in hot weather?
I noticed when I drive at night my car can barely do 40mpg. When it's hot out and during the day I get high 40's.
I tried to do the warm air intake on my last car and the mileage actually went down. When I put the stock intake, air filter it went back up to normal.
So what's causing the car to get such good mileage when it's hot out?
Old 10-19-2008, 11:57 PM   #2 (permalink)
Could it be accelerating warmup?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-20-2008, 12:34 AM   #3 (permalink)
That has little effect on long drives. I have a scangauge 2 so I can see my numbers.
We're not talking about short trips.
Old 10-20-2008, 12:38 AM   #4 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Humidity?
It will "stuff" the air much more than it would be expanding it from being hot and thus a lot less fuel would be injected in.
Also, you cant compare your old car to yoru new car. They all react differently to WAI and other engine mods.
Old 10-20-2008, 12:47 AM   #5 (permalink)
Metrosexual - '91 Geo Metro LSI
90 day: 50.36 mpg (US)
Gaszilla - '88 GMC K1500 Sierra
There are several reasons. Bassically a cold engine requires a richer fuel mixture to run properly until it warms up. A choke on a carburetor used to perform this function, now its done seemlessly through the fuel injection system -you won't even feel this happening. Cold weather requires longer warm up times.
2 Cold air is denser during cold weather your engine can take in a greater mass of air, and add the corrosponding greater mass of fuel. this will give you noticable higher engine perfomance but worse gas milage
3 veriables in the weather, rain, snow, impede performance and increase drag on the vehicle, both aerodynamically and mechanically where the rubber meets the road.
Old 10-20-2008, 02:13 AM   #6 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
The Santa Ana Winds dude.
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 10-20-2008, 02:38 AM   #7 (permalink)
LOL!
Maybe I should not drive my car at night. jk. Lately we had some really hot days in cali. and my numbers are up there.
Old 10-20-2008, 02:41 AM   #8 (permalink)
1) Warm air is less dense so there should be less aero drag.
2) You are getting the warm air intake effect.
3) Less warm up time but also, parts are looser, oil is thinner etc.
Old 10-20-2008, 05:02 AM   #9 (permalink)
interesting.
Old 10-20-2008, 12:25 PM   #10 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Bingo. Like #3, even if the engine is warmed up, other fluids are warmer and flow easier too, like trans fluid, diff fluid, power steering fluid, wheel bearing grease... it all adds up.
Also the air pressure in your tires changes with temperature, so higher temps = higher PSI and less rolling resistance.
Winter daily driver, parked most days right now
Summer daily driver
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
In a world where Jeeps get horrible gas mileage.... EcoJeeper Introductions 16 03-26-2009 12:09 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
Good take on things (long) Daox General Efficiency Discussion 8 08-30-2008 04:11 PM
