EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   SAE papers? (https://ecomodder.com/forum/showthread.php/sae-papers-9582.html)
Hermie 08-09-2009 05:47 PM
SAE papers?
I'm seeing referrence to SAE papers, and when I went to check, I found out that there's a steep charge for them.
What papers do people here have? I'm interested in reading papers regarding the reduction of both lift and drag.
1999-01-0651 would be a good one for people here to read:
The Influence of Aerodynamic Lift on High-Speed Stability
Abstract:
The effect of aerodynamic lift on both straight-line stability and lane-change maneuverability of several small- and medium-sized European passenger cars has been determined from subjective track tests. The straight-line and maneuvering performance degrades with increasing lift and decreasing pitching moment. Increasing speed exacerbates the problem.
gone-ot 08-09-2009 07:36 PM
...SAE papers are typically not free, unless the original author makes them available to the public.
aerohead 08-12-2009 06:41 PM
Sae
or you could just make the leap to Hucho's book which will have all that and then some.
