Samsung tablet instrument cluster
Although this project was done on one of my EV conversions, it also improves instrumentation for a gasoline powered car. I have a lot of gauges that I like to look at, so I just got rid of my factory instrument cluster and went with a Samsung tablet.
Here is the basic layout: http://i1242.photobucket.com/albums/...ejpg1-1801.jpg http://i1242.photobucket.com/albums/...ejpg1-1693.jpg This is a view of the backside. The tablet holder pivots on the piano hinge, and then stays in place with the magnet on top. When I want to remove the tablet, I just push on the bottom of the tablet and it pivots so that I can pull the tablet out. The two big round things on the side are for my turn signal LEDs, and the two things on the bottom left are license plate bulb holders that now have single LED bulbs, to light up my high beam indicator and park brake indicator. http://i1242.photobucket.com/albums/...ejpg1-2429.jpg This is the front view. The two round things on the bottom right are windows that have my original high beam indicator and park brake lenses glued in from the back. You can see the two LED holes on each side of the tablet, those are for the turn signal LEDs. I did not go with the factory arrow lenses for these, since it is self evident which one is blinking based on its location. http://i1242.photobucket.com/albums/...gejpg1-930.jpg This is a thin plexiglass sheet for covering all the LEDs, and to give it that simple look when it is done. The blue color on this is just a protective film so that I don't leave any scratches on it during fabrication. When that film is pulled off, it is clear. The aluminum structure will be painted black, and then the plexiglass tinted so that you can't see the LEDs. Just black plexiglass to match the tablet, and the LEDs will shine through and be seen only when they are lit. http://i1242.photobucket.com/albums/...gejpg1-525.jpg Here it is in place. http://i1242.photobucket.com/albums/...ejpg1-1748.jpg and here it is flipped forward for removal. There is a finger cutout on the tablet backing plate to make it easy to pull the tablet out with your thumb and index finger. http://i1242.photobucket.com/albums/...ejpg1-2399.jpg These are my EV gauges, and all of the custom gauges were entered manually into the Torque Pro app. All of my custom gauges just dump into the file that has all of the gasoline related PIDs, which is kind of nice when I want to use the same tablet in my gasoline powered Metros. This is my driving screen, which is pretty cool, considering that the motor and controller data is coming from one source, the battery data is coming from another source, and the GPS data comes from the tablet itself. http://i1242.photobucket.com/albums/...age.jpg1_3.jpg Here is my charging screen http://i1242.photobucket.com/albums/...age.jpg1_4.jpg This is my charging screen. All of those small icons are each of my 36 batteries, and the larger icons on the bottom are charging related gauges. This screen is nice to look at when my car is out in the garage charging, but I am inside on the couch. http://i1242.photobucket.com/albums/...age.jpg1_4.jpg Here is a view of the interior of my electric Metro http://i1242.photobucket.com/albums/...age.jpg1_7.jpg |
Beautiful!
I have a Scangauge 2, but I think that the newer technology that we have now has really made it obsolete. The Torque Pro app (and probably a bunch of others) has a lot more information than the old skool stuff, and the layout is a lot easier to read. I use this same set up in my gasoline Metro with all the different gauges for driving efficiently on gasoline, so my Scangauge is just gathering dust.
Here is what the Torque Pro app looks like when I run it on a gasoline engine, just in case Torque is not well known here. (I am guessing that on a forum like this, it is probably well known). These are some of the gauges I like to watch in my old gasoline powered Metros.
http://i1242.photobucket.com/albums/...age.jpg1_8.jpg |
Nice mod. Especially like how one of the most stealable items in your car is easily removed. If it isn't there, it can't get stolen.
Was meaning to ask what software that was in the other thread... thanks for this one!
Does Torque have the option of custom gauges or dials? I'd much rather be looking at sweep gauges for rpm and speed when going down the road. - Also, that charging screen is absolutely wild. All EVs should have screens that detailed! |
Here is a screenshot of my gauge setup in another one of my builds. This one has the screenshot icon that you can touch to get that instant saved into the photo gallery in the tablet. http://i1242.photobucket.com/albums/...g?t=1381450755 |
This was my first tablet dock and it is in another one of my conversions.
http://i1242.photobucket.com/albums/...9529345176.jpg http://i1242.photobucket.com/albums/...9791572014.jpg http://i1242.photobucket.com/albums/...1688211322.jpg Here it is in a traffic jamb. Sometimes when I get stuck in traffic, I switch over to my local tv station so I can watch our local weather girl. I don't pay attention to the weather report, but she has a big pair of you know whats. http://i1242.photobucket.com/albums/...ejpg1-1147.jpg |
I have to admit, that is pretty cool.
Good job man. |
sweep dials
Great idea.
I'm also interested in sweep dials, and the screen shot button is useful as well. |
http://i.imgur.com/o8m3r9M.gif
Huge tracts of land! |
Very cool. Are you using bluetooth or a physical connection to the tablet?
I always liked the idea of a removeable instrument cluster that was coded to your car to eliminate theft.
regards mech |
I didn't know that Torque had a screenshot button, now. So shiny...
I just installed the Ultra-Gauge again, but I might remove it once more in favor of Torque. You can't beat how quickly the UG connects, though. I always feel like it's somewhat of a bother to start Torque every time I get in the car. |
This is really nice. Simple and elegant. But I'm not sure I understand how you're getting the information to the tablet. Does your motor controller connect to the OBD2 bus and spit out data that way?
Do you happen to have updated links? The photos are not showing up.
Defi makes a plug n play OBD-ii gauge system for any phone or tablet on iOS or Android OS. SMART ADAPTER W Summary | Defi - Exciting products by NS Japan
Their website does a bad job of explaining it and the pictures are lame. I have seen it in a NSX and it was beautiful! -Liberty |
Yip torque works great... fully customizable, and even does HUD mode, where it reflects in your window to give you heads up display. Not sure how legal??
