Saturn Aura rental
I got stuck in Dallas today so I rent a Saturn Aura (3.6l) to get home. It was a very comfortable ride. Had all the bells and whistles. About 15 minutes into it my seat get hot and I noticed that I accidentally turn the seat warmer on.:rolleyes:
I left Dallas and the cars outside temperature gauge was showing 100 degrees with a NE wind of 10 kts. I set the AC at 83 degrees and using the manual paddle shifts for the auto transmission headed to Austin. This is an impressive car for FE being so heavy. I don't think the rpm ever got over 1700. At 60 mph the rpm was 1600. At 43 in 6th gear the rpm was 1100. and at 50 it was around 1250. I think with some work this would make a great FE platform. I drove 228 miles and put 6.2 gallons in. That's just short of 37 mpg. This is probably pessimistic because they are never really full when you pick up a rental and they left it idling outside for 10 minutes to cool down as I was filling out the paper work. I think 40 would be do able if not just a gridlock commute. I did get a little help from some NASCAR want-a-be's as looking into the rear view mirror. http://i160.photobucket.com/albums/t...ailgate1-1.jpg http://i160.photobucket.com/albums/t...ailgate3-1.jpg |
Nice writeup -- complete with pics of tailgaters!
BTW, what was your cruising speed and did you use technique? 37 blows away my usual 28-29 in this car (3.6). This was with the 4-speed auto. How did you like the 6-speed? I've rented the Aura a few times and it felt like the steering was heavy and the brake pedal made creaking noises. Comfortable, though. RH77 |
The Malibu is the twin to the Aura. After the strike is over (both cars are assembled here in Kansas City), the 6-speed should be installed in the 4-cylinder, LTZ. So far they left it for V6's only, but really could help the city numbers with the additionally available gears. This is HUGE for GM to try something other than the old 4-speed auto -- which was the only option for most cars. But you're right -- they have it figured out to drop RPMs at cruise, which is a good for any engine size. RH77 |
This was a brilliant car, there is a reason it was the car of the rear. nice to see you blew away the fuel mileage!
I had a G6, which is the same platform as the Auro with the same motor and achieved 37 mpg on a trip from Detroit, MI to Canton, OH. I took some cell phone picks, but I don't know how to get them on the computer. Some great ones of trucks just LINED up in the middle lane passing me on a 6 lane interstate.
Lazarus -
Since the Saturn Aura is the Opel Vectra in Europe, I suspect that the ECU/PCM has some thrifty driving modes. It appears that the new Aura/Vectra will be very nice : NEW: First clear pics of 2010 Opel Vectra/Saturn Aura - May 12, 2008 http://www.leftlanenews.com/opel-vec...ra-future.html http://images.leftlanenews.com/conte...pel-vectra.jpg A CGI Rendering I think Quote:
