Old 06-05-2015, 08:51 PM   #1 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 17.37 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One - '24 Hyundai Ioniq 5 SEL
90 day: 96.88 mpg (US)
Gasoline's Cost in KWH's
Read a interesting piece on the cost to distill gasoline in Kilowatt Hours. Turns out gasoline takes 6 KWH's to distill from crude oil. For example if I get 20 mpg driving at 70 mph this means I am burning 3.5 gallons per 70 miles. Normalized to 100 miles is 3.5 x 1.4285714 = 4.9999999 gallons per 100 miles. Rounding up to 5 gallons (justified here) means it takes 5x6 KWH's = 30 KWH's for me to travel 100 miles in this example. You could compare this directly to BEV and the amount of electricity it would take to drive an electric car the same distance.
When you consider that gasoline has 114,000 BTUs per gallon of energy content then 114,000/3,412 = 33.41 KWH's of energy content plus 6 KWH's to distill. So, your gallon of gas really is worth 39.41 KWH's technically. So if I am using 5 gallons of gas to go 100 miles I am really using 197.05744 KWH's to travel 100 miles in this instance. I am pretty sure if you compare this to any BEV that you will find the amount of electricity needed to go 100 miles is substantially less.
"FOOD FOR THOUGHT" This is just me doing some chicken scratching here. Does anyone have any thoughts on this scenario here? Even a vehicle getting 40 miles per gallon still needs almost 100 KWH's to go 100 miles by this kind of reckoning.
The Following 2 Users Say Thank You to aerostealth For This Useful Post:
aerohead (06-06-2015), freebeard (06-06-2015)
Old 06-06-2015, 05:13 AM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
But how many kWh does it take to produce one kWh of electricity?
The Following 2 Users Say Thank You to oldtamiyaphile For This Useful Post:
aerohead (06-06-2015), pgfpro (06-06-2015)
Old 06-06-2015, 05:58 AM   #3 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
You could also say that gasoline is not so much an energy "source" but a solar charged battery that took over 69 million years to charge. A day with PV doesn't sound so bad any more.
The Following User Says Thank You to hamsterpower For This Useful Post:
Old 06-06-2015, 07:51 AM   #4 (permalink)
IamIan's Avatar
Just some other numbers along this train of thought.
AFAIK About 3-4x as many input.
Name:	U.S. Oil Refineries electrical use 1988 to 2001.JPG
ID:	17888   Click image for larger version
Name:	Oil Income Tax Breaks 95.JPG
ID:	17889   Click image for larger version
ID:	17890   Click image for larger version
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following User Says Thank You to IamIan For This Useful Post:
Old 06-06-2015, 01:55 PM   #5 (permalink)
This is a real eye-opener. Similar to the rule of thumb that f you haul firewood more than 60 miles you're better off burning the gas for heat.
Old 06-06-2015, 02:35 PM   #6 (permalink)
...beats walking...
Ain't nothing free.
The Following User Says Thank You to gone-ot For This Useful Post:
aerohead (06-08-2015)
Old 06-06-2015, 07:59 PM   #7 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
I'm trying to figure out why this is in the aerodynamics section...
The Following 3 Users Say Thank You to whatmaycome14 For This Useful Post:
aerohead (06-08-2015), IamIan (06-07-2015), user removed (06-06-2015)
Old 06-06-2015, 09:44 PM   #8 (permalink)
Sorry about where it is posted, but it is interesting. This is the reason fossil fuels will go by the wayside however. The storage energy density and cost per KWH of capacity is getting past the tipping point. Internal combustion engines just will not be able to keep up in efficiency as compared to electric drive once the energy density storage/cost problem is solved. We are nearly there.
The Following User Says Thank You to aerostealth For This Useful Post:
Old 06-07-2015, 07:58 AM   #9 (permalink)
IamIan's Avatar
Some places the tipping point has already passed ... other places will not be far behind.
By 2012 U.S. installed PV cost was a median $5.3/w with larger over 10MW installs ranging from $2.5/w to $4/w Link .. that's a significant drop from the $6.2/w median of just 2010 (previous posted graph).
For those that fell into the $2.5/w installed ... that is effectively getting roughly ~$0.10/kwh electricity ... many places around the country are more expensive than this for fossil fuel grid electricity.
With an BEV that gets roughly ~4mile/kwh ... that's only ~$0.025/mile for fuel cost.
Gasoline @ just $3/gallon (average over the next 20yr) .. would have to have a car getting over 120MPG just to break even with that $2.5/w BEV RE-PV fuel cost per mile.
The US national electric grid had a median cost of $0.0934/kwh in 2010 .. with specific locations varying from as low as $0.0421/kwh to as high as $0.3013/kwh.
Some of those high $/kwh locations are already past the tipping point , and are already cheaper for PV fuel BEV than pump gasoline.... but the others at the very bottom lowest $/kwh in the country will probably be the last places that will pass the tipping point ... to beat both $3/gallon ICE Pump , and the $0.0421/kwh BEV fossil fuel grid cost .. PV in those locations would have to get an installed cost under ~$1/w ... that low will take a while yet.
The Following 2 Users Say Thank You to IamIan For This Useful Post:
aerohead (06-08-2015), freebeard (06-07-2015)
