Scan gauge 2 xgauge question
Does anyone know whether there is a way to get an a/f ratio reading on an x gauge.
That's not going to be possible without adding a wideband O2 sensor to your exhaust system.
Have a look at http://ecomodder.com/forum/showthrea...uges-2375.html
I posted this question on a couple of other forums and here is the answer I got on one of them.
TDX: 616AF10114 RXF: 044145140000 RXD: 2808 MTH: FFFD00020640 NAME: A/F Scan gauge 2 xgauge question - CleanMPG Forums I haven't tried it yet so if anyone comes up with anything else please post it. Hopefully I'll get around to trying it tomorrow. After doing more calculating the original post on the other forum has changed the configuration of the math to cut down on some of the erratic reading. The new math is: Math: FFFE0001066B |
