EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Scangauge 2 TFT display (https://ecomodder.com/forum/showthread.php/scangauge-2-tft-display-15583.html)
sonnyivo 12-26-2010 05:59 PM
Hello everyone.
I got my Scangauge 2 days ago.
Could not get it to display the Automatic transmission fluid temperature,though.
If anyone could post the code for that it would be appreciated.
Toyota Echo 2004 A/T
Thanks
Angmaar 12-26-2010 06:14 PM
This post might help you.
Welcome to the forum.
mcrews 12-26-2010 07:56 PM
I ended up installing a regular gauge and patched into the trans line with the sensor.
Which is ok.....but.....
I still get plenty of information of the SGII
sonnyivo 12-27-2010 03:45 PM
I tried the 2 codes provided .....sorry do not work....
sonnyivo 12-30-2010 09:11 PM
I found the needed code
:thumbup:
Hello guys finally i found the code i needed.For anybody who might need it in the future...it is:
TXD: 686AF101B4
RXF: 044105B00 00
RXD: 2808
MTH: 00090005FFD8
Thank you again Angmaar.I found it through the link you sent me.First time i used the spaces between the letters and it didn't work.Tried without them and everything is fine now.
