EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Scangauge doesn't work (https://ecomodder.com/forum/showthread.php/scangauge-doesnt-work-4554.html)
lovemysan 08-14-2008 10:38 PM
I tried to put the scangauge in the suburban and it doesn't work. I plug it in and it doesn't get any power. The screen stays dead. It works fine in everything else. I double checked and it worked fine before and after the suburban.
wriley4409 08-15-2008 03:36 PM
Make sure that you don't have a blown fuse in your Suburban. This MAY be the cigarette lighter fuse, but I am not 100% sure.
Good Luck,
Wayne
lovemysan 09-01-2008 10:49 PM
I called tech they suggested the fuse also. It was a blown lighter fuse causing the issue.
