EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   ScanGauge II speaker mount for 2001 Toyota Echo (https://ecomodder.com/forum/showthread.php/scangauge-ii-speaker-mount-2001-toyota-echo-11913.html)
alohaspirit 01-18-2010 04:32 PM
8 Attachment(s)
Ive been thinking about a SG mount for a long time now. So I fabbed one up. If you worked straight through from start to finish it will probably take you an hour or so.
I could have just drilled 3 holes in the speaker cover but I dont have a spare cover.
Its also reversible this way. I do plan to cover the surrounding hole with coroplast or something. This probably cost me $5 to make.
What I used:
Thin cardstock (for template)
Thin sheet metal
Metal snips
Metal file (to smooth edges)
Drill
Screwdriver
2 Screws
3M Velcro
I had it behind the steering wheel but its not a great place since the surface is curved.
(It'll come off eventually in time)
http://ecomodder.com/forum/attachmen...p;d=1263850283
So I popped the speaker cover off.
My echo didnt come with tweeters so its an empty space with 2 places for screws.
I made a template out of cardstock, traced it to thin sheet metal,
then cut a plate using metal snips. I then smoothed the edges and
and screwed it down to the existing holes.
3M heavy duty "velcro" works really well and I was able to run the cord down.
(If you look through the windshield, it literally drops straight down to the OBD port)
I like how close it is to the windshield. I keep my eyes on the road
and even have a small amount of room to put up the sunshade.
gone-ot 01-18-2010 05:19 PM
...sneaky cool!
alohaspirit 01-26-2010 03:42 AM
im still thinking of ways to make the surround
any suggestions?
Daox 01-26-2010 07:49 AM
Fiberglass is the only thing I can think of.
gone-ot 01-26-2010 07:51 PM
...how about that "home-improvement" foam in a can?
...make a mold (wax paper?), spray in the foam; let it harden, sand down, and cover with suitably colored cloth, tolex, or faux-naugahyde.
...for a tight fit, wrap the SGII (without cable) in wax paper and position in as you want within the mold.
k.civic.f4i 02-02-2010 07:00 PM
stay away from the foam in a can!!!! it's evil. fiberglass is the way to go. fairly easy, just time consuming.
123456 02-02-2010 07:21 PM
any suggestions?
small sheet of...
aluminum diamond plate
Carbon fiber sheet (not fabric, 6"x6" chunk should do)
fiberglass (fairly work intensive, for such a small piece)
abs plastic sheet
choroplast (if your really have to:( )
thin wood
thin wood upholstered
to name a few :D
k.civic.f4i 02-06-2010 05:29 AM
why dont you just cut a hole through the thing that was originally there enough for the bracket to fit? would look really oem. or pick one up from a junkyard and cut that up.
