Old 11-29-2009, 11:05 AM   #1 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
90 day: 53.2 mpg (US)
Odometer Accuracy for tracking mileage
I just filled up last night and I have kept written records of miles and fuel used since I got the car. I have a ScanGuage II and it showed a 854 mile tank. The VW odometer showed only 836 miles since the last fill-up. I calibrated the SGII to the highway mile markers to get an accurate mph reading. Most VW owners report the speedometer is about 3 mph higher than actual speed. I have since gotten a GPS and just wondered what would be MOST accurate: odometer, SGII or GPS? I could leave the GPS in the car and only reset the trip feature at fill-up to get miles per tank. Would this give me more accuracy than either of the other two?
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
Old 11-29-2009, 01:47 PM   #2 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
I calibrated my odometers using my GPS. Cars were about as dead on as you could get; truck was +4.5% due to the bigger tires. I add 4.5% to my "miles travelled" when putting tanks into the garage.
Old 11-29-2009, 10:15 PM   #3 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
I'd go with GPS for best accuracy too.
I don't have one, and have measured my odometers very closely by using Google Earth!
Using Google Earth to verify your odometer accuracy - MetroMPG.com
COcyclist (11-29-2009)
Old 11-29-2009, 10:32 PM   #4 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 VW Golf
So GPS has the best accuracy. I use mine in several different cars though. If I calibrate the ScanGuage II using the GPS, is the SGII accurate enough that I should use that reading instead the odometer when logging fuel economy in my garage?
TDi=fast frugal fun
Old 11-29-2009, 10:53 PM   #5 (permalink)
My car's odometer is off since swapping for the taller final drive transmission from a model with different size tires.
After figuring out the difference against Google Earth, I now do what Clev does: I add something like 6.5% to the distance traveled shown on my odometer for doing fuel consumption calcs in the garage.
But I'm just being a geek. I have the ScanGauge speed/distance offset set at +6% - it doesn't do decimal places, which is why I do the math myself to get that extra 0.5% accuracy.
You'd be fine going with the calibrated SG distance.
Old 12-02-2009, 07:22 PM   #6 (permalink)
discovery's Avatar
I think the best is the GPS, go for it.
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
My New 4cyl Compact Doesn't Get Good Mileage Stone Axe Introductions 13 02-08-2013 12:06 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 55 08-20-2012 11:34 PM
Using Google Earth to measure odometer accuracy MetroMPG DIY / How-to 10 07-12-2011 03:38 PM
Checked your odometer, lately? NeilBlanchard DIY / How-to 22 01-01-2010 11:02 PM
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
