EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   scanguage for carb (https://ecomodder.com/forum/showthread.php/scanguage-carb-4120.html)
kermitthefrog 07-28-2008 02:49 PM
scanguage for carb
Is it possible to adapt the scanguage to read sensors for carb?
ie, fuel flow sensor
cfg83 07-28-2008 03:32 PM
kermitthefrog -
No, I don't think so. The SG is designed for OBDII cars that are 1996 or younger.
I think the vacuum gauge is the way to go for carbs. Do you already have a fuel flow sensor for your carb?
CarloSW2
kermitthefrog 07-28-2008 04:03 PM
I have a fuel flow sensor, but it's not installed. I got it off eBay a while ago.
I was thinking of some 'hacks' to adapt it.
dcb 07-28-2008 08:00 PM
Fundamentally you just need to keep track of the number of pulses received from the flow meter, though there may be a calibration curve to take into account. Starting with an mpguino would be the quickest path to an mpg (or L/100k readout methinks.
Do you have specs on it?
What's the range of flow rates it works with?
How much was it?
Thx.
