Schematic question
Hi,
Newbie to this type of high power design: I have 2 electric forklifts to play with as guinea-pigs for this testing:) 1) I was wondering what the purpose of the original dump diodes into the 24 470uF caps from the motor+ to the positive battery buss. is this for clamping inductive spikes gen'd from the motor? or regeneration purposes? 2) for reversing the motor, do you guys use a big contactor to reverse the leads ( prior to insuring a shutdown or idle state of the controller? Thanks in advance!!! -Lee |
do you have the schematic?
ecomodder.com/wiki/index.php/Open_ReVolt/PCB_Schematics]Open ReVolt/PCB Schematics - EcoModder[/url]
oh yeah! this is the schematic that Paul use for controller.you will find more on his website
