Schlieren video for testing aerodynamics ?
Imagine having someone video, or photograph your moving car using the Schlieren method.
It seems like a really useful tool. It's probably too expensive though. It also looks complex to set up, and seems to just have a small area in which it can view. Anyone researched this further ? http://www.youtube.com/watch?v=lSFwH0BVd3Q |
Besides showing the airflow on small objects, like this bullet, Schlieren photography can also show airflow on larger objects like this jet ( even seen from a great distance ).
http://www.aerospaceweb.org/question...et/bullet2.jpg http://content.answers.com/main/cont...6800FG0010.gif ( Hmmm... why are those two pictures just showing up as links ? ) |
method
C'mon guys ... I thought you all were into this sort of thing. :)
Did anyone watch the video ? You can clearly see in real time the airflow from a guy coughing, and the airflow from a soda as the guy opens it. If a car drove by as the camera was on, you could clearly see the airflow over the car, as well as the areas of turbulence. ------------------------------------- Phil, tufts and dirt roads don't show the full picture quite as well as this method does. I'm just wondering what is wrong with it, otherwise it would actually be used for aero research ( on cars that is ) . |
from what i've seen it' can't be that expensive in comparison to running a wind tunnel. i didn't see to many high tech things involved.
it reminds me of a construction site i saw a while ago. the site was right next to a road and shielded with tall fences covered with some fabric to protect the cars passing right next to it. as a car passed you could see the air push the fabric against the fence. it was as if the car was enclosed in an invisible bubble of air. would be great if you could see the whole picture like with this technique |
I think we can all remember seeing this effect, as the shadow from a hot car shows this effect well.
I know I personally have seen it numerous times. Here are some stills from the video : http://farm3.static.flickr.com/2533/...30a0c4a8_b.jpg http://farm3.static.flickr.com/2561/...f4aedf6b_b.jpg I called a couple of camera shops and they were clueless. |
I found this, but can't open the link : Cookies Required
The title is : Inexpensive schlieren video technique using sensor dead space as a grid Opt. Eng., Vol. 43, 2501 (2004); doi:10.1117/1.1804546 |
Anyone looked into this ?
What all is involved with this technique ? Can we do it at home with an amature set up ? Please. Any feed back would be nice. Is my tone offensive or something ? ( I need to use more of these : :) in my posts ) |
you wikied Schlieren?
Schlieren - Wikipedia, the free encyclopedia http://en.wikipedia.org/wiki/Schlieren_photography Sounds pretty straightforward, will need some computing power to make a pretty and affordable picture out of it though. |
To me, it seems like a complicated solution. Tuft testing is more elegant, isn't it? And it doesn't require you to be looking at a computer screen - you can see the airflow, unmediated.
No, I hear you, and I'm very much interested in aerodynamics. I just don't know how to go about photographing a car at highway speeds using this technique.
The only Schlieren photos I've seen are of dramatic aero events, like shock waves and sneezes. The result is 2D, and it really would take 3D to properly illustrate the aerodynamic defects of my car, like the side mirrors. A virtual wind tunnel is where it's at. I'd love to set one up. I don't know OpenFOAM, but if you figure out how to toss a SolidWorks model into OpenFOAM or some other software package, and get a Cd out of it, I'll whip up a 3D model of a car with and without mirrors, with and without side skirts, with smooth wheels, etc. Actually, this paragraph has been kicking around in my head for a few months, and it's probably worthy of its own thread. |
It is conceivable to make an inexpensive diy 3d laser scanner, feed that into open foam, and model your car that way.
It is equally conceivable to adjust the computer model till you like the numbers, and have the same laser scanner highlight (directly on the car) the spots where you need to build up and where you need to sand down on your car/plane/boat. |
Schlieren photography is very much used in wind tunnels to show pressure areas and turbulence. It has been used by aircraft and auto companies using scale and life size models to develop the best aerodynamic shape. I first saw it used on a school trip back in 1970 at a NASA windtunnel. Google it and lots of sites are there.
But now it is easier to use CFD computer modeling instead of having to build an actual model or prototype. Just yesterday I started a thread about we ecomodders doing it for ourselves. Building a model database to test various aerodynamic modifications for validity before possibly wasting money on something that does not work. Model it and then build it right one time. See: http://ecomodder.com/forum/showthrea...gram-9944.html |
I must remind myself ( again ) to Wiki and Google on a topic before I post. Sorry folks
While I would love to do CFD calculations, I'm not good at all in math. With this Sclerian technique, I was hoping for a simpler method that would be easy for me to play around with. I was really just wondering if this sort of thing had been thought of before. ( I had originally envisioned driving a car already tufted past a stationary video camera. The tufts would show the flow on the surface of the car, but the Sclerian effect would show what the wake was doing. ) |
The last time that I tufted my car, I had intended to have a large vertical piece of cardboard mounted behind the car. As air spilled off the back of the car, the tufted piece of cardboard would show the pattern of my wake.
I ran out of time though ( rain ) . |
You can use this laser scanner to 'model' your car in less than a tenth the time it takes to model it freehand ( It will be more accurate as well ).
Post images - we would love to see your progress ! The link : DAVID 3D Scanner |
That's very cool. There's little evidence of large objects being scanned though, and I imagine the resolution of a car would be low. Still, it's worth a punt! I'll add it to the (long) list of items on my todo list.
If you look at the image gallery, there is a scan of a person from head to toe.
If you took the car in sections, such as doing a fender, you could piece the 3D data together to form the complete model. The nice thing about 3D modeling is that you can do a copy-flip-attach and mirror the work you have done. You would still have to scan the entire underside though, since it is non symetrical. Did you notice that the program is FREE for the low res scanning version ? Just a couple of years ago, they were selling stuff like this for over $ 5,000. |
Yeah, I can't believe it's free software. Brilliant! When I find the time, I'll try it out.
