Schulich Delta Solar Racer
The Ars Technica interviewer is technically sharp and concise:
https://youtu.be/HRmpgV8xyw0 ~14kWh lithium pack, 23.4% solar cells with a way to bend the light coming in at an angle, 97-98% peak efficiency motors, sleek aerodynamics. http://www.livingtravel.com/australi...2_DSC00836.jpg |
Those panels that "bend the light" seems to only work marginally better than traditional tempered glass panels with sun light coming from a less than desirable angle.
