EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Schultz's Jetta aero mods thread (https://ecomodder.com/forum/showthread.php/schultzs-jetta-aero-mods-thread-1368.html)
metroschultz 03-01-2008 11:48 AM
Some of you have seen my ability to bounce from one project to another. Well this will be done before any others are again visited.
My Daughter (Krissy) has a VW Jetta.OK I own it and fix it and insure it, but she puts gas in it.
I got extra inserts for the lower bumper cover.
I filled them with Expanding Foam. That did not work as planned.
I then filled the top (front?) with epoxy.
That hardened to a granite like surface that has proven very hard to work. I have been able to sand it to the point where I can fill the recess with "Bondo"
http://i259.photobucket.com/albums/h...z/DSCF2350.jpg
Lotsa sanding after this pic. and then.
http://i259.photobucket.com/albums/h...z/DSCF2354.jpg
BONDO!!
I use paper plates to mix in. They are disposable, rigid, & no one cares if I destroy one or two.
http://i259.photobucket.com/albums/h...z/DSCF2352.jpg
Now i must wait for the filler to set and back to sanding I go.
Going lurking now.
S.
MetroMPG 03-01-2008 11:56 AM
Schultz - why didn't the foam work?
I see you showed pics of the initial steps back here: http://forum.ecomodder.com/showthread.php?p=8127
But you didn't say why it didn't turn out.
metroschultz 03-01-2008 12:12 PM
my bad.
It was too soft for any real effect. i was hoping to use my glazing putty to fill in the voids and then just paint to match. I couldn't get the glazing putty to work in the foam because the foam was too resilient. had too much bounce or something. the putty would set and then a little motion or twist would flake it right off. i used the foam as a base for the epoxy resin. which in itself turned into a workout.
fwiw i will try using coroplast under fiberglass filler then topped with glazing putty. next time.
i have some regular putty on it right now, after it sets a bit i will sand and glaze. then sand and paint.
Gotta get this done. K spends most of her time on the highway. So. Aero is the way to go.
she is coming over later and i would like to be able to plug these in.
I have some racing discs for her wheels, i must drill some retaining holes in them for the screws.then no one can steal them and they won't fly off on the highway. I bought the inexpensive ones. i couldn't force myself to pay an extra $75 for someone else to drill them.
Back to work.
S.
metroschultz 03-03-2008 09:40 AM
Aero Inserts ala Schultz
I have completed the inserts for the Jetta. I think they look quite good.
http://i259.photobucket.com/albums/h...z/DSCF2355.jpg
So here they are after Glazing putty.
http://i259.photobucket.com/albums/h...z/DSCF2356.jpg
And here we have the finished product. They are not really this shiny it is a trick of the light. I Sanded them to the shape I wanted, then Painted with a Matte Black Lacquer.
Install will be this Friday. More pics then.
http://i259.photobucket.com/albums/h...z/DSCF2357.jpg
These are the wheel covers for Her car. I should have them drilled and ready by Friday also.
I will take pics after the I finsh with this car stuff and hopefully #1D will have a gas slip so I can make a log entry.
TTFN
S.
metroschultz 03-10-2008 12:57 PM
Friday wasn't good for me!
O.K.
I got nothing accomplished on Friday. I was Ill.
or Saturday, saw the Doc,
Thought it was nothing, wrong.
Feeling better, still not up to par.
or Sunday.
http://i259.photobucket.com/albums/h...z/DSCF2363.jpg
This is a full on front of the inserts. Since #1D spends most of her time on the highways, aero is the way to go.
I will close the gap in the very bottom of the bumper and finish with a belly pan. I have ordered VW's cover for the upper grill. It is OEM and removable if things get too hot.
http://i259.photobucket.com/albums/h...z/DSCF2361.jpg
This is what she looks like right now. I have expended all my energy for the day. Wife and Daughter are both Ill now also. I need to get all the way better so I can get back to work.
TTFN. S.
SwamiSalami 05-02-2011 11:38 AM
Hello metroSchultz,
i was curious, does your daughter's jetta have steel wheels or are they "rims" like most vws? I'm wondering, because if they're rims, how did you get these wheelcovers to work?
Sincerely,
me
mcmancuso 05-02-2011 11:42 AM
you can use hooks with threaded shafts, put the hooks behind the spokes, then put them through the cover(use a pizza pan) and use bolts to tighten them down, use locknuts with the built in plastic washers.
SwamiSalami 05-02-2011 11:59 AM
i would think that this would compromise the smoothness of the cover, though, right? defeating the purpose?
I wonder if I could put a single screw right through the middle?
mcmancuso 05-02-2011 12:01 PM
compared to the spokes, a couple nuts sticking out is pretty minimal. usually the middle cap doesn't have anything substantial to hook to, but that would be better.
SwamiSalami 05-02-2011 12:04 PM
I haven't seen too many threads based on people modifying their rims. It's always the people with hubcaps. I've looked, too!
Can't anything be easy?
metroschultz 05-02-2011 01:12 PM
Wow! this is an old thread.
Her Jetta has steel rims with caps.
Unfortunately the moon discs did not last long. She tends to 'Curb' the tires a lot.
We looked into the screw on style and decided that would not be in her best interest. So back to the OEM VW wheel covers we went.
As of right now she has lost the inserts for the front bumper. and we removed the grill block due to overheating issues. I purchased the OEM grill block designed for the diesels and it looks good while working well also.
The car has been abused unmercifully since we got it and I have told her I am not putting any more time or money into it.
I hope you have better luck.
If I can find the grill block I will PM you if you want it.
Arragonis 05-02-2011 04:26 PM
Hi,
Did you block the upper grill with the OEM block, do you have pics of it ?
Cheers
SwamiSalami 05-02-2011 09:36 PM
very cool, I'd like that.
sorry to hear about your jetta. I know all about "curbing". women seem bad about this. my wife's jetta takes a lot of curb abuse as well.
metroschultz 05-03-2011 12:00 AM
Originally Posted by Arragonis (Post 235628)
Hi,
Cheers
Yes, I used the OEM grill block designed for the diesel Jetta.
No, I don't believe we have any pics, but I will look tomorrow when I am more awake.
It's not 'MY' Jetta any more. I signed it over to my daughter a year ago so she could be a more responsible adult. I quit paying for the maintenance etc. Now the car is turning into a POS. One good outcome, I don't get the reminders for the parking tickets and taxes, etc.
