Schwinn Hybrid bicycles
I see Schwinn has three Hybrid bicycles listed on their site. They are brushless motor hubs on the front wheel.
http://www.schwinnbike.com/images/ca...7_CAMPUS_M.jpg Stylish alloy frame with integrated rear rack. 21-speed Shimano drivetrain for accurate shifting performance. Comfort-enhancing suspension fork and seatpost. Equipped for commuting; rack, fenders & bell. Long range – Hi-tech patent-pending lithium polymer battery is the lightest and most durable on the market. One charge will last approximately 60 miles(Depending on user weight, climate and terrain). Plug n’ Drive – The lithium polymer battery is easily removed for recharging due to our Plug n’ Drive system. There are no wires connected to this system. Lightweight – Schwinn Electric bikes set a new benchmark for electric bikes. Frame materials are aluminum while the electric drivetrain weighs in at about 10 lbs. Hybrid – Ride Schwinn Electric bikes as a conventional bike or as electric bikes. Fast recharge – Our proprietary battery charges fully in less than 4 hours and provides 100% power to the motor until the point when the battery is fully depleted. Internal electric cable routing – Clean looks and added protection. Easy wheel change – The front wheel can be disconnected without dealing with cumbersome wires Specifications: Color(s) M - Black, W - Silver Size(s) 17" frame (26" wheels) Frame Schwinn aluminum with integrated rear rack. Low step thru Women's. Fork Suntour NEX-4000, alloy crown & alloy lowers, coil spring with adjustable preload, 63mm travel Crankset SR/Suntour XR-170N, 42/34/24t, 170mm Pedals Nylon dual-compound comfort pedal Front Derailleur Suntour XCM-102 Rear Derailleur Shimano TX-30 Shifters Micro Shift twist shifters Freewheel Shimano 7-speed, 14-34t MegaRange Chain KMC UG-51, black Rims Alex DM18, alloy 36H Tires Kenda 26" x 2.125" Front Hub Schwinn Mini Motor with alloy shell, 24v, 180 watts continuous; 250 watts max Rear Hub Sealed alloy Spokes UCP steel 13 gauge Nipples CP Brass Front Brake Tektro Alloy Linear Pull Rear Brake Tektro Alloy Linear Pull Brake Levers Alloy Handlebar Steel trekking w/ 50mm rise Stem Kalloy alloy with adjustable rise Grips Schwinn Comfort Headset NECO 1-1/8" Alloy A-Head Saddle Schwinn padded vinyl Seat Post Alloy 27.2 x 300mm Seat Clamp Alloy clamp Battery Schwinn lithium polymer 10 AH battery, charger, integrated into frame tank Extras Integrated rear alloy rack with integrated battery carrier and patented Plug-N-Drive system, front and rear full wrap fenders, At $1900, it sure ain't cheap for something probably made in China and it doesn't even have regenerative brakes but it could make a bike practical transportation where it's hilly and you have to arrive at work no smelling like a locker room. |
Do electric assists on bikes usually have regen brakes?
I was thinking the same thing when I asked. If you ever question what technique to use in a car, go try them on a bicycle and you can probably get your answer :D
actually schwinns are really nice bikes you gotta be really into them to admire them my old friend has a garage full of them I think he got rid of most of them but it was a nice little collection of bikes maybe 25-40
Here's what is cheap!
