Science!
Objective proof that weight reduction improves performance, with significant implications for general engine efficiency! Science!
https://m.youtube.com/watch?v=csSWprl81CI |
Been done before :-)
With lots of numbers.... SCC Technical Assistance Program Where they started... http://www.nerocam.com/SCC_Images/image003.jpg |
Actually one of Hot Rod magazine's most famous articles 'Caddy Hack' from 1987.
"The staff took a ’70 Cadillac Coupe De Ville, loaded it with dudes and surfboards to make it weigh 6,780 pounds and ran 17.22 at 80.01 mph at the dragstrip. Then they cut the entire body off the car, reducing weight to 2,900 pounds and improving e.t. to 13.55 at 100.83" |
Problem with weight reduction is it pretty much has to be designed into the car from the ground up then use the power of mass production and buying in bulk to make it cost effective.
If I wanted to put lighter wheels on my leaf it would cost hundreds of dollars per wheel even after I factor in selling my old ones. |
I always refer to this guy on the TL forum. He cut 800 lbs from his ride.
https://acurazine.com/forums/3g-tl-p...st-1-a-610974/ If I ever want to go faster, I'll take the motorcycle. |
Colin Furze did some weight reduction here: https://m.youtube.com/watch?v=TVJLItZAax4
