"Scientists are
using sunlight to turn plastic waste into clean fuels like
hydrogen, offering a breakthrough solution to both pollution and energy challenges. While still in development, the approach could transform trash into a valuable resource for a low-carbon future..."
https://www.sciencedaily.com/release...0504023841.htm
Here's the
direct link to the research mentioned in that @SciTechera
Opportunities and challenges in sustainable solar fuel production from plastics
This is primarily a perspective/review from Adelaide University researchers highlighting recent advances in solar-driven photoreforming of plastics (like PET and polypropylene) into hydrogen + valuable chemicals (formic acid, acetic acid, etc.) using catalysts such as Titanium Dioxide and high-entropy oxides.
Related/Supporting Research
High-entropy oxide/oxynitride catalysts for plastic photoreforming
This is a real, active research area with promising lab results on turning plastic waste into clean hydrogen and chemicals using sunlight.
It’s still early-stage (challenges with real-world mixed plastics, catalyst durability, product separation, and scaling remain).
But the concept is solid and gaining traction.
(Naturally you will be 6 billion dollars and 6 years into this and still wondering where all the:
"You need this, that and the next 1000 licences, permits, safety studies etc" and just plain bribes came from...
So no; your DIY solar home plastics recycler is NOT available at Walmart)
