Serial Hybrids
Neil -
http://bioage.typepad.com/.a/6a00d83...c183970c-800wi It's complicated, but I think it's a neat way to compare trade-offs. CarloSW2 |
I think NVH = noise/vibration/harshness?
They are showing the fuel efficiency as the weakest point of using the Wankel -- that is too bad then, because that is the main reason to *do* this? |
re: graphic, it is interesting that they score the 1cyl REM and the 2 cyl REM identically in the fuel efficiency and Raw emissions department. I was sorta of the impression that less cylinders was in the direction of more efficiency, right or wrong.
