EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   SG2 - Negative MPG ? (https://ecomodder.com/forum/showthread.php/sg2-negative-mpg-14488.html)
Arragonis 09-08-2010 03:07 PM
Had a busy day today and had some time limits which meant I had to use higher speeds than normal. So I took advantage of fuel cut-off and higher speeds to get my instant SG2 MPG to read as high as possible (e.g. 5645mpg) whilst coasting at 80+ - I have a 6sp so why not use it :thumbup:
The SG2 and on-board averages are getting much closer - despite not being below 75 much on the way back I got 56.7 on the SG2 and 57.2 on the on-board.
Anyhoo one thing I did notice was on some occasions the SG2 actually read negative instant MPG on a couple of occasions. It was when things were 'complicated' - e.g. in traffic, around the transition either to or from a pulse vs a glide - so I can't pinpoint exactly why.
Anyone else seen this ?
Piwoslaw 09-08-2010 03:28 PM
Damn you're good!!!
euromodder 09-08-2010 05:48 PM
Originally Posted by Piwoslaw (Post 193112)
Damn you're good!!!
No, he's getting too good, and tailgating me :D
Angmaar 09-08-2010 08:50 PM
Negative MPG doesn't even make sense.
Going negative miles in a gallon?
Arragonis 09-09-2010 12:06 AM
Well, if MPG = Miles travelled / fuel used
then if Miles or fuel is negative then the result could be negative.
I was going forwards at the time so I suppose the engine was putting fuel back into the tank from the exhaust. :eek:
*(goes off to find patent lawyer...)
IsaacCarlson 09-09-2010 12:11 AM
Are you sure you sere sitting in the front seat? I know some like to drive from the back seat...
Arragonis 09-09-2010 12:33 AM
The roundy thing was just in front of me, if that helps ?
