EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   SGII + ICE OFF = .003 cpm? (https://ecomodder.com/forum/showthread.php/sgii-ice-off-003-cpm-2167.html)
Chris D. 05-05-2008 04:38 AM
Can anyone explain to me how ICE off is causing my SGII to read .003 CPM?
Shouldn't that be zero? :confused:
http://www.youtube.com/watch?v=k3Zwd_kTWb4
Daox 05-05-2008 06:49 AM
There is a fuel cutoff setting somewhere in the setup menu. If your gauge doens't go to 9999 mpg with EOC you need to look at playing with that setting.
Chris D. 05-05-2008 09:37 PM
would you have any idea which way I need to adjust it from my prior position?
does this mean all of my other readings are way off if this is reading like that?
Daox 05-06-2008 07:56 AM
Adjust the value down. The advice I've gotten from others is make sure your car is warmed up with no accessories no and then see what the GPH (gallons per hour) are at idle. Set your cutoff just below that value and you should be good.
thebrad 05-09-2008 12:25 AM
MASTER!
MASTER!
Chris D. 05-09-2008 01:45 AM
I cant get this calibrated for nuttin here..
any locals wanna school me?
no matter which way I adjust it I always
have something as a cpm with ice off..
defective SGII? defective owner? ;)
cfg83 05-09-2008 02:00 AM
thebrad -
Originally Posted by thebrad (Post 24451)
MASTER!
MASTER!
Shake?
http://tbn0.google.com/images?q=tbn:...asterShake.jpg
CarloSW2
