EcoModder.com
-   Saving@Home (https://ecomodder.com/forum/saving-home.html)
-   -   Shorted out my solar PV panel - half voltage now. Help diagnosing? (https://ecomodder.com/forum/showthread.php/shorted-out-my-solar-pv-panel-half-voltage-7843.html)
MetroMPG 04-11-2009 08:43 PM
I mistakenly crossed wires hooking up my 80w panel to a battery this afternoon and screwed something up.
Spark! And now it's only putting out half the rated voltage.
I've posted details and a photo (of my failed attempt to diagnose/fix it) at EcoRenovator. If anyone can offer advice, I'd appreciate it.
I done a bad thing: need advice diagnosing shorted PV panel (output = half voltage) - EcoRenovator
Silveredwings 04-11-2009 09:04 PM
Depending on the type of encapsulating material you have, there may be a depotting solvent that will cleanly remove it and give you a better look.
Ryland 04-12-2009 12:46 AM
sounds like you cooked a diode.
MetroMPG 04-12-2009 01:43 PM
Mystery solved: cooked one and a half bypass diodes. :)
One blew clear apart (which is fine - the panel can work without them). But the second one fused when it melted, creating a dead short around half the cells in the panel, thus the 1/2 output.
Thanks for the help.
